Senior Member
Doug Zielke's Avatar
Cams vs. emissions
If I knew more about the art and science of cams, I could probably work this out myself. What I need to know is if a mild cam upgrade for (CIS) SC motors will affect a smog test.
The cam I'm considering is the WebCam 20/21 grind, which some of you have already installed. Looking at the specs (lobe center, overlap etc.), tells me it's a pretty mild stick, but I'm looking for comment from those of you who actually have them in your engine.....and have taken a smog test or had a gas test done.
It's just too much work to re & re cams for the annual smog test I have to face here in the Rainforest, so I won't be doing this mod if it will cause a test failure. Your thoughtful input is greatly appreciated.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 09-24-2002, 07:49 AM
Senior Member
Superman's Avatar
Doug, couple of things: First, my e-mail is not reliable right now and I'm wondering when this engine drop will occur. October 5? 12? I do have a strategy to share regarding how to place the floor jack against the motor's bottom while distributing the engine's weight more broadly. A small piece of plywood and a 1x4 down the center of the case will distribute the weight between various spots on the case, and even some on the heat exchangers.
Also, I have not smogged my engine, but would be happy to offer it up for some experiments. JW will probably know whether the 20/21 cams can pass smog, and if I need to stop there to experiment, then....it's always a pleasure to visit John's shop.
Mocha 1978 911SC. "Coco"
Old 09-24-2002, 08:02 AM
Senior Member
Jim,
The Blue Bomber Engine Drop will be held on Saturday, October 12.
I will be sending out official invitations (and directions to the garage) next week, but you are already on the list.
Old 09-24-2002, 10:16 AM
