-   -   Fog lamp switch removal (http://forums.pelicanparts.com/porsche-911-technical-forum/794703-fog-lamp-switch-removal.html)
Wew 02-01-2014 04:56 PM
Hi all,
Had the broken, cracked fog lamp switch. Thing snapped off after I initially unscrewed.
What on earth do you use to loosen the housing pictured below. I got a replacement ready to screw in but that darn thing wont budge. Any tips or suggestions are appreciated.
Thanks,
Garyhttp://forums.pelicanparts.com/uploa...1391302555.jpg
http://forums.pelicanparts.com/uploa...1391302566.jpg
Wew 02-01-2014 04:58 PM
Better pictures
At least biggerhttp://forums.pelicanparts.com/uploa...1391302670.jpg
http://forums.pelicanparts.com/uploa...1391302690.jpg
AJ's 911 02-01-2014 05:21 PM
I would take the black plastic washer with the 4 holes off first. I used a couple of forks and bent the tine and stuck one on opposite sides and unscrewed it (counterclockwise). You can also use needle nose pliers.
To remove the metal piece that broke off the switch, use a vice grip and unscrew as well. Good luck!
allaircooled 02-01-2014 07:25 PM
I used snap ring pliers on mine.
pors1968 02-01-2014 07:31 PM
If you can try to move the swicth behind the dash because black plastic washer is jam and is easy to cut the dash.
