flatsixcrazy's Avatar
How to mount Cibie Oscar hood light?
Hi.
While looking through some of the old rally pictures, I noticed that some rally cars have Bosch (similar to Cibie Oscar) hood lights mounted on the front hood, as opposed to the more $$$$$ Pallas. I have a set of Cibie Oscars that I'd like to replicate this look. Does anyone have pictures of how these lights were mounted, including under the hood brackets? Thanks in advance.
Old 01-31-2014, 05:28 PM
porwolf's Avatar
Here are a couple of pictures I found in my files:
Here are some links:
Cibie Oscar light install
IROC build - Am I nuts for drilling holes in my hood?
Lets See Fog Lamps!
Pictures of short hood cars with rally lights
http://www.****************/picture-gallery.php
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 01-31-2014, 06:58 PM
porwolf's Avatar
Here is a source for under-hood brackets:
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 01-31-2014, 11:14 PM
Wayne that is good news, I've been toying with making some pallas style shells to take oscar lamps and rings , a poor mans solution if you will.
During my thinking and fiddling I noticed that an oscar has a pivoting mount carried in a pressing riveted to the lamp shell. So I drilled out the rivets leaving a hole in the oscar shell. A flat plate can be welded over the hole and the lamp shell simply bolted down using a pallas type load spreader under the hood.
The best bit is this allows an oscar to sit right down on the hood, I need to solve aim adjustment but mocking it up I think careful positioning will be the key. Sorry no pictures since I'm still messing with it as a hospital project but food for thought.
Old 02-01-2014, 12:58 AM
Tony
Maxhouse97's Avatar
Wayne are you going to get any of the Cibie Marchal style repro by chance?
Tony
22 GT4
04 E46 M3
87 Carrera (sold - craving aircooled again)
12 991 Carrera (sold)
Old 02-01-2014, 05:56 PM
I heard rumors, a few months ago, that Rene is back in the game. It looks like that this is no longer a rumor and good news indeed. Hopefully, the price and quality remains comparable to the last batch he did.
Haasad, I also couldn't see how the "pivoting" Oscar type, when mounting on the hood, would be as stable as the Pallas' mounts that porwolf mentioned, and thought of doing the same thing as you are to a set of Oscars I have. Hopefully someone who has mounted a set of Oscar on their hood could speak to their stability.
Old 02-01-2014, 06:32 PM
If you decide to mount Oscars on the hood, a support stay will have to go from near the top of the housing to the hood . so two holes for each unit.
Otherwise expect to see the lamps flopping back and forth twisting the hood surface.
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 02-01-2014, 06:58 PM
bavaria911's Avatar
Wayne,
Thanks for getting the Cibies back, please keep the price reasonable. Unlike Sierra Madre price at $652 per light !!
Vr,
Scott
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 02-01-2014, 08:14 PM
irl irl is offline
irl's Avatar
Send a message via AIM to irl
TRE, can you explain further and show an image of what u are talking about.
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 02-01-2014, 10:42 PM
I took a couple of pictures to try to illustrate my thinking, don't think there'll be any need for additional support( beyond a palllas style plate).
My thinking is to blank the hole where the pivot bolt went with a flat section. Cut a rubber gasket, seat the lamp on the hood and fix with two or three bolts through to a pallas esque plate under the hood. It would be neat to get a gasket compliant enough to use the mount bolt tension to aim up and down. As i said still at the thinking stage but it has potential.
Andy
Old 02-02-2014, 04:59 AM
