-   -   3.2 Carrera cold running issue (http://forums.pelicanparts.com/porsche-911-technical-forum/794735-3-2-carrera-cold-running-issue.html)
brown911 02-01-2014 11:34 PM
Hope I can get some pointers to rectifying the issue of my 1986 Carrera, being that every time I take it out, it stalls after lifting of the throttle until the engine has reached normal operating temperatures. So I assume I have some issue with the cold start / running setup???
Cheers
Flat6pac 02-02-2014 03:23 AM
You might ohm the temperature head sensor to see if its working. Specs are available for it.
Bruce
Chuck.H 02-02-2014 06:06 AM
Also check the ICV (Idle valve) - does it correctly idle high like at 1100 RPM while cold?
Chuck.H
'89 TurboLookTarga, 372k miles
