-   -   engine code 930/03 (http://forums.pelicanparts.com/porsche-911-technical-forum/795351-engine-code-930-03-a.html)
LCOX 02-06-2014 08:03 AM
engine code 930/03
Engine code 930/03. What displacement and year production is this engine?
onboost 02-06-2014 08:18 AM
Are you sure that's 930/03 ?
Bob Kontak 02-06-2014 08:21 AM
The 76/77 3.0 Carreras were 930-02 and if sporto trans 930-12
http://forums.pelicanparts.com/uploa...1391703699.jpg
onboost 02-06-2014 08:28 AM
Yes, and the 930/04 is 78/79 3.0 SC
BlueWing 02-06-2014 08:29 AM
My 79SC 3.0 liter ROW is a 930/03
Terry
LCOX 02-06-2014 08:31 AM
This engine is in a 1978 Euro version 911. The date of production sticker in the door jamb shows 5/78 as the production date.
The engine has a green shroud which I've only seen on 2.7 engines.
The date stamped in the engine case appears to be 930/03 but I'll check again.
onboost 02-06-2014 08:32 AM
Terry
ding,ding, ding.. you got it!
I just checked the number on one recently sold.. duh, that's what it is!
nathanbs 12-12-2016 05:21 PM
Is this at all special or meaningful versus 930/04 or only maybe to someone with a '79 ROW SC?
nathanbs 12-12-2016 05:29 PM
May have answered my own question. Looks like 29 more horsepower in '79 compared to the US version
tcar 12-12-2016 06:21 PM
Yes, same big runners, big valves but higher compression ratio than US engines.
cmonref 12-13-2016 04:26 AM
Where do you see the 29 HP increase? From the chart above, looks like 930/03 (ROW), 930/04 (USA), 930/05 (JAP), and 930/06 (CAL) for '78 and '79 are the same at 132KW.
javadog 12-13-2016 05:00 AM
Ahh, no.
High compression? Ahh, no.
To the OP...
The green shroud is wrong. Start looking to see if other parts are wrong, too. Start withe intake and CIS parts.
JR
nathanbs 05-25-2017 07:30 AM
Originally Posted by javadog (Post 9394669)
Ahh, no.
To the OP...
JR
yes my mistake. just higher torque
Simon's Porsche 911 SC Site
Iciclehead 05-25-2017 08:04 AM
I have two 930/03's....
European SC ('78)
Nice engine....and one of them came with a green shroud standard.
Dennis
1979-930 05-25-2017 08:13 AM
The 30 Nm more torque is interesting.
Is it the lack of emissions equipment or a different camshaft? I guess both to get that big of a difference at the same RPM??
javadog 05-25-2017 08:23 AM
Same cam, slightly different timing, a little more fuel/air and one change in the exhaust.
JR
1979-930 05-25-2017 09:54 AM
^^^ Thanks.
I do remember seeing the different distributor curves in the shop manual now that you pointed it out.
It's funny how less timing will make a car pass emissions. I used to have to retard the heck out the timing in my Mustang to get it to pass with the cam that was in it. Ahh the 80's.
Flat6pac 05-25-2017 09:59 AM
The only thing I physically found in the early euro 3.0 was the .25 base gasket vs the .5 base gasket.
I never found the cylinders to be different like the Carrera euro and US which have the same casting numbers but different piston heights.
Bruce
