-   -   Compression check (http://forums.pelicanparts.com/porsche-911-technical-forum/7955-compression-check.html)
not_sure 09-07-2001 07:51 AM
Compression check
What do I need to do this at home, how much will it cost me and how the heck do I do it?
Tom
Superman 09-07-2001 10:47 AM
You need a compression tester. Remove all spark plugs. screw the tester into a spark plug hole and run the starter for 5 or 10 seconds. Be sure to pull the fuel pump relay or make sure somehow that the system is not delivering fuel.
Read the gauge on the compression tester and go to the next cylinder. The actual testing procedure takes just about 15 minutes. Accessing the spark plugs is harder than the compression test itself.
'83 SC
not_sure 09-07-2001 02:34 PM
Can I pick up a gauge at sears or any other automotive type place?
Steve F 09-07-2001 02:44 PM
Absoulutly http://www.pelicanparts.com/ultimate/biggrin.gif http://www.pelicanparts.com/ultimate/biggrin.gif$35at Pep boys,just bought one.May the blue bird of happyness bring you bring you good readings http://www.pelicanparts.com/support/smileys/lol2.gif
[This message has been edited by Steve F (edited 09-07-2001).]
Steve F 09-07-2001 02:46 PM
Absoulutly http://www.pelicanparts.com/ultimate/biggrin.gif http://www.pelicanparts.com/ultimate/biggrin.gif$35at Pep boys,just bought one.May the blue bird of happyness bring you bring you god readings http://www.pelicanparts.com/support/smileys/lol2.gif
1967 912 "in progress"
Now ,with a 2.0 T4 to play with!:d
Steve F 09-07-2001 02:47 PM
Wow! http://www.pelicanparts.com/ultimate/biggrin.gifI need to go home!
