kinein's Avatar
Send a message via Yahoo to kinein
SWB Front Suspesion Swap to Front LWB
Up to what year can I directly bolt on a complete front suspension to my 66 912 front suspension, the only thread I found is this one.
Early SWB 911/912 front suspension swap
Can I go up to Mid 80's?
1966 912 with 2.2 911 motor
1986 wide body 911
1995 993 Polar Silver
Old 02-08-2014, 09:20 PM
300hp 1800lbs is the goal
pksystems's Avatar
Depends on your front strut towers.
Do you have the adjustable kind, or the fixed tops like they did until '66.
If they are adjustable you should be able to use parts up till '89.
I have Carrera front parts on my '66 912, but I grafted in the adjustable towers.
SWB upper strut mounts ??
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 02-08-2014, 10:17 PM
kinein's Avatar
It seems to be the adjustable strut tower
1986 wide body 911
Old 02-08-2014, 10:34 PM
kinein's Avatar
So a complete front suspension up to 89 will bolt right in? A arms etc.........
1986 wide body 911
Old 02-08-2014, 10:42 PM
Bye, Bye.
Scooter's Avatar
Yes, any complete suspension up to '89 will fit a SWB, regardless if fixed top or adjustable.
Elvis has left the building.
Old 02-08-2014, 11:18 PM
