-   -   getting keys question (http://forums.pelicanparts.com/porsche-911-technical-forum/795827-getting-keys-question.html)
ThomO 02-09-2014 09:08 AM
I have a 69t that is a major project. It came without keys what do you think is the easiest way to get keys
Is there someone that has a service
BeeMaster 02-09-2014 09:36 AM
For my 76 911S I just took my title to the local porsche dealer and they had porsche in Germany cut a new key. Took 2 weeks . If you go in with just your vin number they won't order it they want proof you own the car. Got the new key and it worked perfect.
bfunke 02-09-2014 05:04 PM
Call Tony Eugenio. He's the expert for early Porsche keys and locks.
70basket 02-09-2014 07:15 PM
I went to the dealer about a year ago with my title for my 1970 and they told me that they could not get keys for my car, it was too old. I wonder what year is the cutoff if BeeMaster got keys for his 76. I ended up buying a used ignition lock with keys from our host's used parts forum.
ThomO 02-10-2014 12:35 PM
Yeah I contacted the dealer and the cutoff is when vins switched over to start with WPO
I will pm bfunke to get Tony's contact info
daleflesburg 02-10-2014 12:53 PM
I do not want to be stupid, but how do you start your car? How did you get it home?
ThomO 02-10-2014 12:56 PM
It is a project car roller that I had delivered
It is a ways from running I am just tracking down missing items while it is to cold work out in the shop
daleflesburg 02-10-2014 01:07 PM
You will need to get a tumbler from one of the doors and or the ignition switch. Tumbler removal not too difficult. Once you have a tumbler out and secure (will be made more difficult without a key, you can send the tumbler to Tony and he can make you keys. Might want to remove the entire ignition switch assembly and just send it to Tony. Tony Eugenio is at 610.461.0519
bugmeat 02-10-2014 01:10 PM
Tony Euganeo is your man:
Home | LockAndKeyID.Com
ThomO 02-10-2014 01:20 PM
Thanks for the info
FrenchToast 02-10-2014 02:54 PM
That's odd. '76 would predate that era. 1981MY is the year for VIN federalization (when they started using WPO).
Chuck.H 02-10-2014 03:04 PM
I'm sure Tony is the man, but I'd also bet you could remove a tumbler and take it to an old-school locksmith/key guy in your hometown and he'll cut you a new key (assuming he has a blank) from looking at the pins. I just got a spare key made for my '89 at the local guy when I realized he had the old blanks, cost was $2.25 out the door.
Chuck.H
'89 TurboLookTarga, 372k miles
Flat6pac 02-10-2014 03:12 PM
Tony can feel cut the ignition and the alarm key, worked times for me.
Bruce
BeeMaster 02-12-2014 07:49 AM
I just got the new key 6 months ago. Sounds like they aren't telling you the truth.next time I am in there I will ask how much farther back they can go.
jac1976 02-12-2014 08:56 AM
Took the door handle from my 73.5 to a local locksmith and he cut me a key a few months ago. If they don't have Porsche blanks, there are those from another car (Volvo? Pontiac? Don't recall) that will also work. Your local Porsche shop has likely run into this problem before and can direct you to a capable locksmith.
KNS 02-12-2014 09:00 AM
For the guys that had the dealer order a new key, what was the cost? Thanks.
ClickClickBoom 02-12-2014 09:13 AM
I got one of these:
917 style key
Spendy, but every time I turn the key I feel like an old, fat, ugly Steve McQueen!
BeeMaster 02-12-2014 12:18 PM
$100 for the key (metal only), $40 for the plastic part you turn Then they clip together and you have a full key. You can reuse the plastic and key ring from your old key if you want and save the $40.
BeeMaster 02-12-2014 12:29 PM
But from the sound of things it not all dealers are created equal so to know what you
Would have to pay you have to go in and ask. Oh and the plastic part you turn has a little flashlight in it
Salty Springs 02-12-2014 12:36 PM
you can buy the blank and the flashlight fob on Ebay (genuine Porsche)for about $54.00
+ shipping
BeeMaster 02-12-2014 12:49 PM
If your dealer won't order it call international autos in Waukesha, ask for the porsche department
And see if they will order you one. Again they want to see the title for proof of ownership so you may have to fax or email them a picture of it. But call first they are very professional and acomidating. Parts 262-754-0911 x354
jac1976 02-12-2014 04:15 PM
Our host doesn't seem to offer key blanks for that particular year. However, if you search the web for "1969 Porsche key blank," you will find them widely available for $10 +/-. It takes a few minutes to get the door handle off and a few bucks to have a key cut...seems easier and considerably less expensive than jumping through hoops at a dealership or with Porsche Cars North America.
tctnd 02-12-2014 08:29 PM
There is a paper sticker on the ignition lock ( the metal steering lock part, not the electric switch) with the ignition key code. You will need a mirror, flashlight, and flexible neck to find it, but once in your hand almost any locksmith can cut you a key.
regards,
Phil
ThomO 02-13-2014 07:33 AM
thanks
thanks for all the suggestions
ThomO 04-01-2014 01:52 PM
Figured I would close the loop on this one.
I talked to Tony and had to remove my lock cylinder from my door handle and send it to him. He decoded the pins and cut me a key.
Pretty straight forward process and cost me $40 plus the shipping to him.
One project down one gazillion left.
