What Paint For Trunk Area?
I am in the process of stripping/painting the inside of my trunk compartment and was wondering if anyone could offer a nice rust inhibiting paint for the job?
I thought about purchasing some of the spray-on or paint on bed liner stuff and giving it a try. Anyone have any other suggestions?
Bill
William Armentrout
1973 911T
2.7 carerra rs specs
Old 09-05-2002, 04:55 AM
Cool
if you have rusted areas I would use Por-15 as a base coat..other than that check out what your body shop supplier has in the zinc area...........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-05-2002, 06:20 AM
I have a little surface rust. Not bad at all though. I think it was caused by a bad trunk seal. I am going to install a new seal after I prep and paint the trunk. Thanks for the input!
Bill
William Armentrout
1973 911T
Old 09-05-2002, 08:14 AM
Zeke's Avatar
I have used both POR 15 and Hammerite smooth on my car. Completly different paints although both tout application over limited prep. The POR 15 is icrediblily hard and shiney. the Hammerite is less shiney, takes forever to cure, but can be exposed to the sun. Both flow well making them fairly easy to handle. Due to POR 15's high cost, I used it directly over rusted areas and did the trunks, engine bay, interior and the entire bottom with Hammerite.
Old 09-05-2002, 08:29 AM
