-   -   Removing CIS tips (http://forums.pelicanparts.com/porsche-911-technical-forum/79654-removing-cis-tips.html)
82SC 09-04-2002 08:30 PM
Removing CIS tips
I am trying to remove my entire CIS system in one piece...is that possible?
the only problematic manifold bolts look like cyl 5 and 6...
has anyone done this...any tips? I don't want to take apart all my fuel injection stuff....
thanks
MJ
Chuck Moreland 09-04-2002 08:43 PM
I think you are asking if the intake runners can remain connected to the airbox while the assembly is being removed. Yes they can.
I have done this, and put it all back together as a unit. No special tips for you, some of the bolts are hard to reach but all are doable.
Doug Zielke 09-04-2002 08:53 PM
It's a snap...when the motor is out of the car.
I saw it removed in one piece (at Superman's engine drop clinic) with my own eyes.
When it's sitting on the work bench, it looks like a big insect. A real big insect!
82SC 09-04-2002 09:25 PM
well the engine is on the ground...
and it is 2 pesky bolts...I think it is doable with the right extensions and such....
but I've given up for the night...will finish tomorrow
MJ
BenWillis 09-05-2002 07:52 AM
Make sure you account for every nut and washer BEFORE you start to lift the runners off!!!!
It was'nt fun fishing the one washer I missed out of cyl number4 with the engine still in my car!!
stlrj 09-05-2002 01:42 PM
It's much easier to do if you do a partial engine drop by removing the rear engine mounting bolts and lowering the engine about 6".
Joe
