Correct wiring on my Fog Switch ?
Hello !
Can anyone tell me if this is the right wiring on this fog switch ? The switch has the terminals 1,2,3 and K. Grey wire to #1 ? Blue/white wire to #2 ? Small red wire from Ligth bulb holder to #3 ? and Brown Wire from # K, to cigaret ligther ground ? I think this switch goes from 74-80 See Pictures. Is this Correct ? EMAIL: isteindsn1@gmail.com Regards Řistein __________________ Oistein Norwayhttp://forums.pelicanparts.com/uploa...1392491938.jpg http://forums.pelicanparts.com/uploa...1392492200.jpg http://forums.pelicanparts.com/uploa...1392492215.jpg |
Fog Relay wiring
Ok,thanks for answers have the switch sorted out.
Next question is about the relay: My car is a 75 Wiring diagram from 76 shows: Red wire to#30 White /green to #87 Blue/white to #86 White extended with brown with white stripe #85 (Ground) When i ohm the White extended with brown with white stripe, it's connected to #86 And the Blue/white is connected to #85 Does it matter or do i have the wrong diagram ? Does anyone have wiring froman 75 ? Regards Řistein |
Oistein,
Send me a PM with your email address and I will send you the drawings for your '75. |
| All times are GMT -8. The time now is 04:23 PM. |
