The reason I started this post was I could just buy a new VR but if the problems come back (after I go through the wiring of course) then I've got a new VR that I can't use because the only thing left is to replace the alternator. I'm hoping to get back to it tonight. Will keep you posted on the progress. Think I'm going to take this as a chance to go through and do some other work. I replaced the rear fuse panel and cleaned up all those connections already. I bought one of Fred Cook's front fuse panels but haven't installed it yet. Think I'll do that too. There should be no chance of poor grounds when I'm done! |
As mentioned before on my Landcruiser that has a standard dashboard voltage meter I found that very useful to monitor my battery charging situation constantly. When my charging was weak I could see the battery voltage drop substantially below the normal 13.8V. Sometimes with headlights on It dropped to almost 12V. After the car heated up sometimes the voltage was back to 13.8V sometimes not. It always happened here in the "winter season" in Southern California, never in the summer. Some times I had to recharge the battery with a charger. I am not absolutely sure that another reason was not a slipping belt. I changed that and tightened it. So far not a problem anymore. So, I don't know whether it was the VR or a slipping drive belt, or both. Anyway the fix was cheap. Hope it holds up. Now I want install a voltage meter in my '79SC" together with a CIS pressure meter on the center console. I like to see what is going on all the time.
Time for an update. I sent off the fan and housing to Mark Motshagen to powder coat it while I had it out of the car. I'm taking the opportunity to do some other work during the downtime. I started taking a closer look at the alternator. No obvious issues with any diodes or the windings. However, I did find a place on the positive side where the wiring looks like it is flaking (possible charring?) and there is definitely some corrosion.
Here is a couple of pics. Sorry if the quality is not good. It is hard to take a pic of this area. Is this a potential concern? If so what should I do about it? Seems odd because the alternator itself doesn't seem that old. Appreciate the help... http://forums.pelicanparts.com/uploa...1394428338.jpg http://forums.pelicanparts.com/uploa...1394428357.jpg |
Last night I posted the above update and I got a smart-alecky response from what I suspect was a spammer. Looks like that response got deleted by a mod so I'm not sure if people saw my update and follow-up question. If anyone has an opinion on whether the above would cause a problem I would appreciate it so I can figure out the next step.
I don't know if a visual check of the alternator is the way to go. Can you take it in to an alternator shop and have it tested under load? We call that smart alecky spammer "Loren". So you can now address him by name.
If the alternator checks out, then you may have a bad ignition switch. The radio acting weird, windows, car won't shut off, etc etc are all symptoms of that too. |
Nah. It wasn't Loren. It was garbled list of letters guy.
I have already taken it to a shop but they didn't find anything. It was recommended that I do a visual inspection. That was the only thing I turned up. |
Tim, what was the outcome of your alternator problems? I'm having issues with mine again with an intermittent voltage change, charging to no charging. I have a post going on this.
Bob |
Long time, no see! Short version: took my old alternator to local repair shop. They said it bench tested fine. All symptoms pointed to a failing VR or alternator diodes though. Problem was, if I bought just the VR and the problem was still the alternator then I have to buy a new alternator (that comes with a new VR) or find another shop that can rebuild the alternator PLUS I would have to R&R the alternator AGAIN. So I ended up buying a new Valeo. There is a guy that sells them on Amazon for a reasonable price. Installed the new one and the problem went away. |
Tim, can u send me the link for the Amazon guy? I have not been able to locate a new one incl with our host. They say they r back ordered with no time est. I ended up with a rebuilt Bosch which was supposed to incl rewinding and all the other stuff so in theory it should be good as new....but I'm having issues. Is your ride back together yet? Porsche gathering this Sunday at that warehouse.
Ok I went back in my Amazon order history and it says "sold by Amazon LLC" -- not sure that helps.
The part number is W0133-1597770-VAL I'm not sure you can use the same Valeo in your '87 though. Engine is still sitting on my garage floor BUT I am now making steady progress. Getting closer every day! |
i see the new alt fixed it???
those solder joints look ok. you want to look for small cracks or lines in the joints. i am going to contradict myself here. yes, hot spots are a sign of resistance and a lot of current making it hot, but with the alt, i dont think this is any problem because they all pretty much do that. they can also burn like that do to a lot of current period, then add in the heat already being generated. i would really lean towards a diode as your problem. as it get hot is stops working like it should. a lot of the ILS guys here at work have to trouble shoot with freeze spray or a heat gun. |
I don't know where this thread has been! Glad you found happiness!! Very interesting.
I have had similar problems for forever and finally pulled my alternator, housing and fan. At everyone's urging I had the alternator rebuilt. Found these guys (Pelicans) in Zanesville, OH - Sagle Auto Electric - who replaced diodes, rectifier, bearing and brushes for peanuts! Very happy. Beautiful work. But can't put everything back as the housing and fan are with Motshagen in California for ceramic coating. I will have to replace my VR as it's a Bosch and the Alternator is a Marshal-SEV. Remember this engine decal: http://forums.pelicanparts.com/uploa...1427389935.jpg Tom |
Bob resurrected my old thread and I'm glad he did. I hate it when people never follow up with their solution and I was guilty myself!
I think the takeaways are: (1) intermittent failures are sometimes hard to find (2) finding competent testers/rebuilders may be an issue |
Bob, you asked about the engine... Here's how it looks as of last night.
http://forums.pelicanparts.com/uploa...1427392179.jpg |
That looks fantastic Tim, will even look better installed. My issue is going to the shop today, jack Lewis. I'll let u know the outcome but it's pointing to the Alt/VR again. At least I have a warrenty for the replacement. Battery checked out fine which is too bad. Would have been less costly.
Tim,
There ought to be a law about having an engine that looks that beautiful. Motshegen warned me about making the fan/alternator housing look too blingey, particularly if the rest of the compartment looks like a chicken coop! Tom |
Like someone walking blindfolded into a field of land mines, I somehow manage to find ALL the slippery slopes. :)
Tim, fixed mine now by replacing the rebuilt Bosch that was causing the trouble with a new velao which is OEM. My mechanic found a new one from one of his contacts as our host and everyone else I checked with had them on back order. All is in order now.
| All times are GMT -8. The time now is 05:27 AM. |
