83 SC Oil Tank leak Fix
I have an SC. It appears that there is a leak from the oil tank sending unit gasket. Of course, after cleaning it up and tightening the bolts, it got worse. I have a new gasket. My experience with working on a 73 911 tells me that there is no way to remove the sending unit to replace gasket without removing oil tank. Are there any tricks that you have to enlighten me?
Old 02-16-2014, 08:42 AM
bugstrider's Avatar
I remember reading a post about that type of repair. However, I did just find this post that might help you out. It deals with the seal and overhaul of the OSU. Good luck.
Copy the following post title and paste it in the search box. It should pop right up.
Oil Level Sending Unit: How to Service / Repair / Maintain
-Palpatine (Robot Chicken)
1978 911SC Targa
Working Projects: 1968 912
Old 02-16-2014, 09:42 AM
You can pull the SC sending unit because there is more room with the flair.
Remember, it has to be spun while removing it from the tank.
Bruce
Old 02-16-2014, 09:48 AM
Thanks!
Old 02-16-2014, 01:54 PM
