Eschews Obfuscation
good night, and when you wake up you'll feel better
so i put my 911 to bed for the winter. not because of poor weather, or salt and gravel on the roads, but because i can't keep oil in the engine. i've been keeping close track of oil loss, and it looks like i'm getting about 300 miles to the quart.
if it's burning oil, i can't see it. maybe it has something to do with that big oil stain in the garage. ![]() i'm going to take the engine out, clean it up, figure out where all the leaks are, and see if i can plug some/most/all of them. i also need to replace the rubber fuel and brake lines. i'd like to replace all the suspension bushings as well. my pelican project list is currently 6532.09 dollars worth of fun, but i've been unemployed for 9 months. i can handle the 9 cents pretty well, the rest of it will take some creative thinking. this ought to be an interesting winter
'84 Porsche 911 Targa '97 Ford F250 Heavy Duty '98 Volvo S70 '02 Subaru Forester '05 VW Passat TDI |
Friend of Warren
If you aren't seeing smoke then I suspect your exhaust valve guides are shot. Oil gets sucked through them and into the exhaust without burning. Leak down test might be in order.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Eschews Obfuscation
so if i have oil suckage past the valve guides, and it doesn't burn, i should be able to feel an oily residue in the tail pipe, correct? if so, is it fairly subtle? i'm losing a lot of oil somewhere.
also, i don't see how the leakdown test will help if the valve guides are shot. as i understand it, the test looks at how well the valves seal against the valve seats and the rings seal against the cylinder walls. if this is true, i can have good compression and leakdown test results with completely worn out valve guides. the engine is a 84 3.2L with 133K miles. the engine has never been opened to my knowledge. i really don't want to have to do a top end on the engine, but i never really want to pay my mortgage either
Sounds like this is going to get expensive quick. Most of the tools you may need the local Pelicans have. Sometimes we even all get together to drop an engine or two. It might help you a bit on the costs anyway.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Fleabit peanut monkey
Recreational User
Worn valve guides are a certainty on any 911 with 133k miles....but that doesn't necessarily mean they're worn to the point of needing a valve job. If they've made it to 133k, then it's normal wear. My '86 is at the same point and it doesn't burn much oil at all.
I'd stick to your original plan...find and repair the leaks, then re-evaluate your oil usage. |
So what's not much oil at all? I get about 600-800 miles per litre of oil depending on short or long distance driving. I have 65K miles on the odometer. I also don't see any smoke. Is that too much?
Eschews Obfuscation
yes, i'm serious. it's not an oil slick (ie, some depth to it), it's a stain (ie, very thin, doesn't really grow, but it's definitely oil on concrete).
what that says to me is that i don't really have a passive leak from the sump bolt, or the oil return tubes, or things of that nature. what i have is an active leak when the engine is running and the oil pressure is up. a couple of drops or so drips down, and then i back out of the garage. when i park the car and shut the engine off. there are small oil spots in three separate locations under the engine. i'm currently running mobil 0w-40, and that stuff is pretty thin. i don't really understand if synthetic oil is absorbed differently in concrete than regular dino oil. i expect to change to valvoline zr-1 15w-40 for the zddp content during this maintenance cycle.
Viscosity may (??) make a difference with a stain on cement but if you have a consistent leak, you could tell pretty easily. If you have time to pull the engine, that is cool, but it sounds like all the stuff you would change/address could be tended to with the engine inside the car. I bet the valve guides are just tired. Clean it up and drive till things get better job wise. Ironic you (we - I'm in the same boat) have time but should not sensibly drop big/medium money right now. Stretch it and drop the $532.09 of the $6,532.09 on tightening a few things up. :-) |
Eschews Obfuscation
what is the current thinking on the hot setup to drop the engine/transmission unit with the car up on jackstands?
i've been hitting on the forum search feature, and am impressed by my complete lack of success in finding what i'm looking for. clearly my search tool-fu is weak, because i can't believe this hasn't been discussed ad nauseam. based on what i've been able to find, it seems that an atv jack is commonly used. are there any specific features i should be looking for? is there some brand or model that is considered optimal? can anyone point me in the right direction?
Motorcycle Jack / ATV Lift - 1500 Lb. Capacity Aluminum Floor Jack - 1.5 Ton Aluminum Racing Jack I've seen the equivalent at Sears and Northern Tool.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Wash. State
Oil....drives most everyone crazy. I have been driving my '86 a lot lately (gotta still be within limits of insurance and such of course) but have found that ZERO leakage and less 'burning' of oil is now the norm. Seems daily pleasure drives down to the water, once or twice to work, etc., does wonders. Drive it, don't let it sit, I say; the cars don't like it.........and yes, go DINO oil. I'm running Valvoline with some extra additive to boost the good stuff (about a pint per gallon). car is running great.............
Wash. State
Friend of Warren
A quart every 300 miles isn't from a few drops of oil hitting the floor and spreading out. Have you looked into a leakdown and compression test?
Eschews Obfuscation
if i don't find evidence of a major-league oil leak, i will look at compression/leakdown testing. edit: i should point out that i see no evidence of oil smoke out of the exhaust. i almost never get exhaust smoke on startup, and i don't see it upon full throttle acceleration, and i don't see it when letting off the gas, and i don't see when getting on the gas after an extended period of the engine slowing the car with the throttle closed.
'84 Porsche 911 Targa '97 Ford F250 Heavy Duty '98 Volvo S70 '02 Subaru Forester '05 VW Passat TDI Last edited by dhagood; 11-30-2011 at 05:38 PM.. |
Eschews Obfuscation
pazuzu, thanks for the links.
It's completely possible that when the engine is running and there is oil pressure, a quart of oil can be pushed out past a leak and drop on the road. When you get home, all you will see is what's left on the case after you shut it down, and that's what drips on the floor. You're oil loss is happening when you drive down the road.
In order to loose a quart in 300 miles from oil getting past worn guides would produce smoke. Additionally, the guides don't necessarily pass oil no matter how worn they are as the oil would need to get past the seal first then the guide. I use a standard floor jack to drop the engine; no special lift required. It's a balancing act but I've done it by myself many times. If you have a floor jack already, it's one more thing you don't have to buy with your limited budget. The car needs to be jacked high enough for the top of the motor to clear the bottom of the rear bumper and placed on jack stands. Then the floor jack, with a piece of 2x12, is used to lower the engine to the ground and out from under the car.
Tell it like it is or don't tell it at all. |
Get a super bright light. I use a small hid light. Crawl around, over and under.
A leak this large should be somewhat obvious. Look for the wet spot. : ) |
Tired Member
Here is my first drop lessons learned post.
First Engine Drop, Lessons Learned... Long It has a link to the actual first drop thread. P.S. don't let these guys scare you. It could be something horrible and expensive but it could be something simple and cheap. If you are not seeing the exxon valdez spill on your garage floor and you don't see smoke or feel oil in the tail pipe. It may be a leak that only occurs when the oil is under pressure (engine running at speed) and warm (thinner oil). You won't know until you get it out. Pull the engine and post some pictures of what you find. And good luck on your job search.
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
Friend of Warren
