Gauges faded needle color?
If anyone can post some pictures of a pristine non faded oil level gauge that would help me on my way to fixing the rest of my gauges.
So I am going to go through clean and repaint all the gauge needles as they are horribly faded.
Low oil level color does not seem to have faded. Or was this a true red, vs the flourcent orange/red that the needles seem to have been
So very close to a good match.
Old 08-28-2025, 03:22 AM
Have been testing color match against a good condition vintage VDO gauge as it doesn't appear faded.
UV LED to test how flourcent the color match is
As per usual I have gone down the rabbit hole.
Old 08-28-2025, 03:48 AM
SC gauge — it’s a bright orange, vs the red bars on the gauge face itself:
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings)
Dynamic CR calculator: https://dcr.questionable.services/
Old 08-28-2025, 04:18 AM
Ok so oil level bar is red, what about redline on the tachometer?
My tachometer "redline" seems to have faded like the needle.
Old 08-28-2025, 05:27 AM
You can put some clea wing on. The gauges too, or your car’s windows. It blocks all the UV (fades the interior and needle paint) and block the IR (heat) to make the car cooler. Just an idea. I like the 3m Crystaline PR70….leaves windows very clear and make a huge difference in heat.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 08-29-2025, 05:36 AM
'87 Targa
reclino, After all your color match work, what paint brand/color is the best match (or color-code)? Just wondering in case I need to refresh my gauge needles someday.
Old 08-29-2025, 07:14 AM
Burnin' Rubber
Koizumi's Avatar
What do you mean by “clea wing”? I know it’s a typo but I still can’t decipher it.
Old 08-29-2025, 02:46 PM
They meant to write “clear film” - the 3M stuff mentioned is an example.
Old 08-29-2025, 02:59 PM
Banned
Sounds like a solid project, repainting the needles will really freshen things up. Hopefully someone can share a clean reference gauge so you can nail the correct color.
Old 08-29-2025, 04:56 PM
This stuff was a very good match… seems to be discontinued , but maybe you can find some.
Old 08-29-2025, 08:43 PM
I concur with @PFNog on the Testor's model paint, though I used FS28915 (fluorescent red), not FS28913 (fluorescent red orange).
https://www.amazon.com/dp/B004QJOCNC
Old 08-30-2025, 02:39 PM
Burnin' Rubber
Koizumi's Avatar
https://www.truenorthpaints.com/paintstore/fluorescent-red-orange
Old 08-30-2025, 03:39 PM
