How often do you change oil
On my 81 targa I just bought on the owners manual I think it's recomended oil change interval is 12000 Kms
How often do you guys change your motor oil ?? Is it longer periods because of our dry sump
Old 03-21-2014, 09:54 PM
LakeCleElum's Avatar
My Porsches: Each year or 5,000 miles.......Since I've only put 20,000 miles on my 73.5 in the last 24 years, do it annually......
Japanese cars and motorcycles: 5,000 miles......
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 03-21-2014, 10:00 PM
Cooper911SC's Avatar
On my '81 SC every 5,000 miles.
On her 993 every 8,000 miles.
Cooper
Old 03-21-2014, 10:07 PM
Fleabit peanut monkey
Bob Kontak's Avatar
See your owners manual, page 74. 15k miles/24k kilometers is the oil change interval stated.
Now, does any Porsche nut go that long, nah. I say annually and don't use thin oil. 20W50 unless you live and drive in the arctic.
1981 911SC Targa
Old 03-22-2014, 03:44 PM
Slippery Slope Victim
NY65912's Avatar
Annually, I never get to put on 5K a year. 20W50 Brad Penn & Mahle filter.
Mike²
1985 M491
Old 03-22-2014, 03:46 PM
Are these longer intervals because of the dry sump system or just because of how much quantity of oil we have
Old 03-22-2014, 03:50 PM
Bob Kontak's Avatar
Quantity. It does not break down as quickly given the large volume.
I am not a scientist but I believe oil viscosity does not break down. Mainly the additives degrade.
1981 911SC Targa
Old 03-22-2014, 03:53 PM
HarryD's Avatar
I am old school and do my 911 and Bus every 3,000 miles. I drive them between 3-4,000 miles a year so it is about once a year with BP 20W-50.
My 2006 and 2009 get a change every 5,000 miles with a synthetic.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-22-2014, 04:22 PM
15k
'90C4
Old 03-22-2014, 08:00 PM
Banned
No doubt the oil company executives love you for it!
Old 03-22-2014, 08:27 PM
Troll Hunter
5000 miles with synthetic on a 996/997? Nuts
Sent from my SAMSUNG-SGH-I337 using Tapatalk
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 03-22-2014, 08:32 PM
HarryD's Avatar
RONNIES.930. No doubt they do but the way I see it, both these cars have 150,000+ miles on them and with the blow by and crap that gets into the oil, it is not about the oil but the removal of impurities in the oil is more important to me than seeing how long I could go.
On my later cars, the longer interval gives me a chAnge about every 8-10 months, so this does not seem excessive either.
If I wanted to test for longer intervals that could be a plan too but at $25-35 a test what the point any money saved on delaying the oil change is at least partially spent on testing
Old 03-22-2014, 08:36 PM
HarryD's Avatar
Bob, correct it is not the oil but the additives and most importantly the ability to neutralize acids from combustion by products that gets "used up".
Old 03-22-2014, 08:38 PM
Banned
Harry, you could buy the cheapest, house-brand oil on the shelves at Walmart, and its additives are not going to be even touched, much less used up, in 3K miles. And if you are concerned that your high mileage engine is polluting the oil at such a rapid rate as to need 3K mileage changes, then you must be driving around with tremendously high piston ring leakage numbers, and/or your fuel system is dumping copious amounts of excess fuel into the oil. If not, those change intervals are complete lunacy.
Old 03-22-2014, 08:53 PM
3000 to 4000 miles for me. I love my 2.7L MFI motor and have driven it 120K miles in 10 years and want to drive it for a long time.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 03-22-2014, 09:03 PM
Banned but not out, yet..
RSBob's Avatar
Annually
Old 03-22-2014, 09:58 PM
AutoBahned
RWebb's Avatar
oil viscosity does break down - sorta
modern multi-viscosity oils are made with long chain molecules that can coil up like springs or stretch out - when those molecules break into smaller pieces you lose the ability of the oil to change viscosity
those concerned about when to change the oil can simply get an oil analysis done
Old 03-22-2014, 11:08 PM
clutch-monkey's Avatar
oil is the cheapest thing you put into an engine.. i do mine a couple of times a year (car is driven as intended though).
i'll dump it after each track day otherwise.
Old 03-22-2014, 11:12 PM
Not only does it depend on how much you drive, but on where you live. When I bought my 964 ten years I was mighty surprised to find about a pint of water drain out of the oil tank before oil started to flow when I did my first oil change. I lived in the Seattle area and found that if my oil change intervals were longer than about 5,000 miles or maybe 6 months, I would get some condensation coming out with the oil. Now, living in a warmer drier climate I see no condensation whatsoever.
Old 03-23-2014, 07:43 AM
Weseeeee911
On my SC I change the oil once a year. I only drive it 4-5000 miles a year so it works out perfectly.
Al
80SC 95-present
Old 03-23-2014, 08:33 AM
