-   -   Zenith Rebuild - My First Carby Project (http://forums.pelicanparts.com/porsche-911-technical-forum/797607-zenith-rebuild-my-first-carby-project.html)
porschetub 05-30-2015 07:59 PM
I had my main bodies lightly washed in a engine parts hot tank as the alloy may be delicate to this process,they came up really nice,but I had little or no moisture corrosion ,maybe differant otherwise for really old neglected ones.
I didn't cad plate throttle cams/linkages or other parts as you can't see them in a 914/6 ;),happy to spend the money elsewhere,it looks nice however.
My carbs in this situation were junk if I couldn't get the remains of the air bleed screw out...I was lucky,had it been brass and not steel it wouldn't have come out.
Research vent size carefully,if you go too big you will move the power curve right out of driving range and have a big "hole " down low.
I ordered 32mm vents and went back to 30mm for my 2.2T ,still a big improvement over stock 27.5mm,reason being I wanted to keep low end torque.
Stoddard Cars in the early days did a lot of R&D with these carbs and reached substantial gains in power by machining out stock vents and upping mains and idles to suit,they fitted the sports 2 pipe outlet exhaust also,they sold is as a sport kit to many happy buyers.
Funny I sort of feel that Porsche chocked back the early 2.2t as the the "E" wasn't that far away powerwise....maybe a marketing exercise ???? who really knows.http://forums.pelicanparts.com/uploa...1433044282.jpg
Pic is stock vent and 32mm like night and day really,cheers.
frankc 10-01-2015 10:08 PM
Awesome write-up - thanks very much for posting this.
I have started the rebuild of the Zeniths for my 2.4, and would like to remove the floats so that I can soak the top section in carb cleaner. There are two screws for each float retainer. One screw is easily accessible, the other is not so easily accessible due to it being under the float. What have folks done to get to that second screw?
chris_seven 10-01-2015 11:36 PM
The die castings used for the manufacture of standard venturis means that the wall thickness is around 1.5mm so it would be difficult to re-machine to an oversize.
Also the shape of the standard venturi is also very poor and this must also restrict flow which means to achieve good mid-band and WOT performance venturis are often larger than ideally needed which has a negative impact at low throttle opening.
In the UK there has been an company called Superflow manufacturing a range of chokes to suit Weber 40DCOE carbs for the last 20 years and the benefits they provide is well understood.
They have an optimised ‘hour glass’ entry which is parabolic in nature and much better that a typical ‘as cast’ component used in a standard carburettor.
The improved shape effectively improves the flow for a given air speed by reducing the Reynolds Number which increases the pressure drop and hence the ability of the metering system to operate effectively.
In real terms good venturi shape means that the carb will operate more effectively at low engine speeds and provide an improved power band.
The impact of using good quality venturis should not be underestimated.
rodoredas 10-04-2015 06:33 PM
Hi frankc,
in post #24 you can see an elbowed flat piece of metal in one of the pix which I used initially with not much success.
In a recent repair of the floats I just used a newly purchased very long thin screw driver which worked fine for me, but like you was stumped a bit the first time I did this.
cheers
Shane
frankc 10-04-2015 08:07 PM
Thanks Shane. I also ended up finding a long thin screwdriver (with round rather than rectangular shaft) that allowed me to remove that buried screw.
Now I have another question - regarding the accelerator pumps. Upon disassembly, I noticed two differences in the center pump mechanism vs. the two outers.
First, as you can see in the photo below, the chambers of the two outer accelerator pumps have three bosses as part of the casting whose purpose, I assume, is to retain the diaphragm spring in the center. However, I noticed that the chamber for the center pump does not have these bosses (or whatever the proper term is). I have only disassembled left carb so far, so I haven't yet confirmed if the right carb is the same, but I found this odd and wondered if your carbs were the same (and why the center pump would be different).
http://forums.pelicanparts.com/uploa...1444017828.jpg
Second, the center pump nozzle (#26 Injector Tube) is also different (see photo below). The part of the outer two nozzles that is inserted into the body is longer, and Part #27 (Plug) just falls out when the two nozzles are removed. However, the center nozzle is shorter and has a jet screwed into the bottom. In addition, for the center nozzle, there is a sleeve pressed into the hole of the carb body with part #27 below it, meaning that #27 cannot be removed without somehow removing the sleeve. Was your carb also like this?
I would like to ensure that the passage to the pump chamber is clear for the center pump, but I cannot do so unless I remove part #27. If I fill the hole for the nozzle at the top with brake fluid, it does not leak out into the chamber, so I assume that the passage is blocked.
http://forums.pelicanparts.com/uploa...1444017854.jpg
rodoredas 10-05-2015 02:21 AM
Hi Frank, I checked a heap of other pictures I have and I'd say that center pump has had a bad time. Like you say I think it should have the 3 studs to hold the pump spring in the centre, all mine did.
Seems previous owners have messed up the injection tube #26 and #27 as well, whatever you have does not look right. The plug should fall out when you remove the injection tube.
You certainly want to make sure all the passages are clean and fuel can flow from the chamber up the passage and out the injection tube. I'd be trying to get whatever is in the hole out and getting new injection tubes.
can you drill out the sleeve you can see, just start with a very small drill. I'd be taking the carb body to a local Porsche mechanic and getting second opinion before doing anything.
cheers
chris_seven 10-05-2015 07:35 AM
I must say that I have never seen a Zenith with 3 x bosses in the central pump location.
We have restored around 15 pairs of cabs and they have all been identical to those shown in the above photograph.
I have also never seen an accelerator pump jet f the type shown they have always been as the two outer jets and have had the small brass 'stop' valve fitted.
The pump jet also has a one-way valve fitted and it is important that this operates correctly.
Most of the repair kits available have O rings for this jet that are slightly the wrong size and don't seal very well.
1QuickS 10-05-2015 07:44 AM
Regarding post #44. If you measure them you will also find the height of the three ears are different for the outer accelerator pump features. I can only imagine the tabs are used to limit the amount of travel of the diaphragm.
When I service Zeniths I counterbore a spot in the bottoms of all three wells of the accelerator pump chamber to locate the return spring; I do not like the lack of the centering(?) tabs in the middle chamber so I provide one in all three. I also remove the tabs to allow full adjustability of fuel squirt.
Jose_JGC 10-05-2015 07:59 AM
Wow!
Shane, thanks for sharing.Excellent work and documentation, I love the paper comments in the pics. I will definitely keep the link to this thread.
cheers
Josehttp://forums.pelicanparts.com/support/smileys/wat6.gif
frankc 10-05-2015 09:35 PM
Well, this is getting interesting. Regarding the tabs/ears/bosses - since Shane indicated that his carbs had them on all three chambers, but everyone else seems to say that they are not present in the center chamber (like mine), could there be two different castings? Perhaps this could be a difference between Zeniths fitted with the enrichment circuit vs. those without?
And regarding the shorter center pump jet, since everyone is saying all three should be the same, I have a theory on what may have happened. Upon closer inspection I can see that there are gouge marks from pliers on the top hex head part of the jet. My theory is that the jet was stuck in the carb body, and somebody forced it out and snapped it at the O-Ring groove - leaving a portion of the jet in the body. So then they drilled out the piece stuck in the body (and destroyed the glass ball), but I can still see the walls of a thin brass tube remaining - just enough to prevent #27 from coming out.
Then, they jammed a jet from someplace else onto the broken shaft of the #26 jet to hold the O-Ring in place. I can see that this "extension" is not on straight - so i presume it is not an OEM configuration. I will know for sure once I disassemble the right carb and compare. But, regardless, I don't see how the center accelerator pump could possibly work well without the glass ball check valve in the jet, but fortunately Alfa sells replacement pump jets.
The pump jet on the left in the photo below is my (hacked) center jet (McGyver repair :)?):
http://forums.pelicanparts.com/uploa...1444109161.jpg
chris_seven 10-05-2015 11:56 PM
These pump jets do break and need replacement but I have never seen a 'bodge' of this type.
The small 'stop valve' that is shown on the other two chokes may still be in place if there is the remains of the old pump jet still in the gallery.
Clearly needs some careful work.
frankc 10-06-2015 06:56 AM
Yes, I can see the slotted top of the 'stop valve' down in the gallery, but the remains of the broken jet prevent it from being removed. I will be sending this carb to a pro to have the remaining piece of the jet drilled out of the gallery as this is not something I want to attempt with hand tools.
1QuickS 10-06-2015 07:28 AM
Zenith bodies differ in progression hole size/locations but otherwise they are the same.
rodoredas 10-07-2015 02:13 AM
Hey Chris I had another close look at my old pictures and zoomed them up and sure enough I've mislead everyone following the thread regarding the 3 bosses in the centre pump, apologies of that. Mine don't have them either. This is the clearest photo i have, clearly the centre pump does not have any. No idea why and didnt really notice that, good pickup Frank. The more people looking at these the better.
http://forums.pelicanparts.com/uploa...1444212420.jpg
Frank, It really seems your set have seen some bad times and rough work, but lets hope you can get it all sorted.
Great tips Paul, thanks, on centering the spring and machining out the tabs, sounds logical.
cheers
frankc 10-07-2015 06:49 PM
Shane,
Thanks for confirming that the center pump chamber on your carbs is different than the outer chambers, just as everyone else's - that's one mystery solved. But I'm still curious why. I mean, from what I can tell, all three pumps are performing identical tasks, using identical components - so why is the center pump chamber different?
Given that it is a German design, I can't help but think that it is different for a reason :).
1QuickS 10-08-2015 07:21 AM
In my work with Weber 40IDA3C, Solex 40PI and Zenith 40TIN I have resolved most design/operation curiosities but this one still eludes me, especially the different height of the vanes in the outer two pump chambers. If the vanes were to be a travel stop to control maximum squirt amount then I would expect them to be equal height. The internal spring is not well located by these vanes so centering the spring does not appear to be the answer, especially since there is no centering feature for the middle spring in its well.
rodoredas 03-28-2017 03:04 AM
Hi Folks
I've had these Zenith's running in the Targa for some time now and I'm now starting to play with different jet sizes to understand and feel the difference they make if performance and acceleration.
My setup was stock 930/16 3.0L engine, 34mm venturies, 165 Mains, 55 Idle, 175 air correction, ignition timing is good, mixture and air bypass all adjusted. Using Synchrometer cylinders were all pulling 5Kg/Hr at 950-1000 RPM, and to me the throttle response felt great, there was no stumbling between 2000-3000 rpm but to me it seemed to be running rich. So I decided to have a play with jets and went to
Mains 140, Idle 50, Air Correction 180 and she was stumbling in the 2000-3000 rpm range after re-tuning to 5kg/hr at 950rpm and lean best mixture, Accelerator jets are 0.5mm (not 0.3mm)
I've now gone Idle 55 (mains 140, air correction 180) and that seems to have alleviated most stumbling but there is still evidence of some.
In doing all this and speaking to guys here some are recommending smaller venturis. The stock ones I have are 28.5, I have 34mm installed. I thought i might install the 28.5 just to see and feel what happens.
I wonder what latest theory is from the Zenith Pelicans on venturi size for the engine config i have. It seemed to me when i did research during this thread that 34 was the way to go. In terms of venturi area the 28.5 provide 637m2 while the 34's give 907m2 - it's a big jump so maybe there is some consideration for slightly smaller venturi - but what size? Targa is mostly street, but track it 3-4 times a year so prefer leaning towards track/street setup rather than street/track if you know what i mean.
what's the latest thinking on this?
carbs and Targa out in the high country.
cheers
http://forums.pelicanparts.com/uploa...1490698664.jpghttp://forums.pelicanparts.com/uploa...1490698664.jpg
rosie82sc 04-21-2017 12:50 AM
Hi Shane,
Just read the entire thread, found it interesting and helpful as I am in the process of rebuilding a 2.7 with zeniths. I will be running bigger cams and pistons so I'm sure there will be plenty of time for test and tune after it's up and running.
Greg
rodoredas 04-22-2017 11:42 PM
Hi Greg
good on ya!. I'm sure you will have a great time rebuilding, tuning and trying different setups. Been running mine for 12 months or so I guess and tinker with different setup all the time and it's great fun.
Currently working through different jet sizes and running taller velocity stacks
cheers
http://forums.pelicanparts.com/uploa...1492933304.jpg
rosie82sc 04-23-2017 02:55 AM
Hi Shane,
I am on a road trip in my SC until next Sunday then plan on placing an order with alfa1750 but would like to have a chat before I do, will PM you with contact details. We will be staying in Melbourne Tuesday night.
Regards
Greg
johnsonfm3 04-18-2019 06:44 PM
accelerator jet removal
Hi Rodoredas,
I thoroughly enjoyed your "how to do it" on cleaning my Zenith 40 TIN
Carby's.
While removing part #26, accelerator jet (injection pipe) from the main carb body it snapped in 1/2 at the waist!!
Any advice on how to remove it?? Perhaps I should try just finger pressure as I was trying to overcome the gasket resistance with a pair of needle nosed pliers...
Thanks in advance,
Fred
johnsonfm3 04-18-2019 07:55 PM
Zenith Rebuild
Hi Shane,
To clarify the above, I'll remove the rest of the damaged accelerator jet by using dental tools etc.,or drill it out.
My question is how to remove the remaining jets. Were you able to remove them with finger pressure?
Mine just snapped, not like frankc described above. It was virgin, but perhaps the "O" ring was stuck!
OBTW, my central accelerator pump chamber has no vanes but the two outer ones do.
rodoredas 04-18-2019 09:43 PM
Hi Fred, thanks glad you enjoyed it, it's good fun and I hope you enjoy doing yours. Yes some are tight I seem to remember, spay some WD40 let it soak 10-15 minutes, then try and twist, they should just pull out with fingers or pliers, just take it slow. O-Ring is sure stuck. I wouldn't drill. Let me know how you get on. Looked at some of the non-published photos my accelerator pump same.
cheers
Shane
Einar Irgens 04-21-2019 11:52 PM
Hi, all.
I am currently working on my second set of Zenith TIN 40 carburetors, and stumbled upon this thread while searching the web for a decent rebuild kit. Impressive presentation by rodoredas! I however have a question. When overhauling the first set about 10 years ago, I reused all the jets. Is this risky? Should any jets or nozzles be replaced by new items just to be sure? Do they wear over the years? Are the ones with glass balls inside more prone to malfunction?
I also have one piece of advice. Before dismantling a carburetor that has not been apart for a few years, make sure to lubricate the idle mixture and air screws also from the inside. If you look inside the bore underneath the butterflies, you will spot tiny holes where the air/fuel enters the air stream. Fill these with WD40 or similar and leave overnight before attempting to remove the screws. When adding torque, the idle mixture screws in particular have a tendency to break at the smallest diameter.
Originally Posted by rodoredas (Post 7921292)
Turbo_pro 05-21-2019 06:38 AM
Cool thread
911 SLANT 02-03-2020 12:11 PM
On my Zenith 40TIN. 165 mains, 185 air correction and 60 Idle air. 34 vents. Running on a 2.7 with 964 cam grind, ported heads, 8:5.1, SSIs and GT3 MK, 7:31 on 915. MSD ignition and coil. Car spats at 3,000. Idles nice at 900rpm. No issues with idle. Will pull at take off up to 5000 . Cruising at 3000 spats. Cruising at 3300 at 70mph it purrs. Should I leave it or figure out why its spats at 3000?
rodoredas 02-09-2020 01:25 AM
Hi 911Slant
I had similar case when doing test drives with various jet configurations - i'd suggest increasing idle jet and or adjusting mixture screws out a fraction - but just do one at a time and see if there's any change.
cheers
DaveO90S4 04-11-2020 02:58 PM
Hi all,
Thanks to all who have posted - great for someone like me who has decided to get to the bottom of their Zenith 40 TIN carb problems.
Not wanting to hijack this thread - but just to say I'm running these carbs on my modified 2.7L Chev corvair aircooled 6 in my Porsche 914 in Brisbane, Australia. Have had the car and carbs to a number of so-called 'experts' and have been disappointed with their work, so have decided to do it myself. Yesterday I removed and plugged the 'auxiliary air enrichment circuit', as seems to be the considered wisdom. Am adding phenolic spacers and am making gaskets above and below to suit.
Running 180 air corrections, 55 idles, 30mm venturis, 135 mains. Runs much too rich, especially at cruise (11.5 AFR), otherwise runs well. I have a range of alternative jets plus a set of 34mm venturis, synchroniser tool, float level gauge, repair / tuning manual, and have been scouring the net for info, and hope make use of this 'at home' time this week to get the carbs back on and see if I can tune it.
Am very interested in other peoples 'best' jet and venturi combinations on (say) 2.4-2.7 L engines.
Again, hope this is not a hijack! ;)
Cheers
Dave
Brisbane, Aus
rodoredas 04-14-2020 06:15 PM
Hi Dave,
good to see another set of Zeniths being put to use. From memory my latest config is idle 57, main 145, air correction 180, venturi 34mm (cars in storage and I can't get to them to check). I'd be upgrading venturi to 34mm - I reckon you need more air. At idle 900rpm I have approx 5Kg/Hr on each cylinder, use the bypass screws to adjust.
Get your hands on the Performance Orientated Weber Tuning document, while it focuses on Weber it's relevant to the Zeniths.
Interesting setup you have anyway with that Chev Corvair flat 6.
cheers
DaveO90S4 04-14-2020 09:56 PM
Hi Shane, thanks for response. And thanks for putting Greg and me in touch with one another.
I agree with your thoughts re reverting back to the 34mm venturis - I did that last night. My thinking was it ran well with 34 venturis when I first used it and before I was persuaded to put 30mm venturis in it.With the 34mm venturis there should be somewhat less air velocity and vacuum pulling the air fuel emulsion through the jets at a given rpm, so that will maybe / hopefully lean it out. I had nearly fixed the transition stumble with the 34mm venturis, and I reckon if I go back to my last 'best' jets for the 34mm venturis I shouldn't have to then make too many more changes to get it right, and hopefully with decent AFR through the rev range.
I think if I could get 13.5 at idle and cruise and say 12.5 at WOT, with good progression, I'd be pretty happy.
Cheers
DaveO
rodoredas 04-15-2020 02:14 AM
Hi Dave
great, I reckon the two of you will sort it out, Greg knows what he's doing.
What tool kit are you using to measure AFR?
Let us know how you get on with tuning and what your final setup is.
I'm hoping we can make it up your way later this year so would be good to catch up with both of you.
cheers
DaveO90S4 04-17-2020 11:54 PM
Hi Shane,
I've installed an O2 sensor in each side, and a pair of AFR / lambda gauges on the dash, so I can monitor both left and right banks. As an overkill I also had one bung per exhaust 'log' so I could monitor individual cylinder AFR if necessary. A bit of overkill really I think.
Carbs back on the engine, may try starting it tomorrow once I've pushed it out of the shed and have fire extinguishers at hand - just to be on the safe side.
Cheers
DaveO
rw7810 09-03-2020 07:28 AM
Somehow I have misplaced/lost an injector tube. Anyone happen to have an extra?
Hi_Fi_Guy 09-03-2020 03:09 PM
You can purchase almost all part for the carbs if needed. Parts Klassik online and alfa1750 on eBay both have just about everything you could want.
stephers 09-03-2020 07:41 PM
Just talked to ************ today out of stock on the acc pump nozzles, not sure when they are getting more
Thanks, Rick
