New User
I know I'm pushing the evelope, but I don't know where else to turn.
I have a friend with a VW Passat. The ABS has gone bad and the estimate is $2,000. Any way to safely disconnect it? |
From my understanding when it craps out you can still brake normally... Just no ABS.
I have seen this true on other cars anyways. ------------------ Adrian Pillow 1979 911 SC 1966 VW Microbus PCA - Peachstate Region |
GAFB
I had a similar experience with a VR6 Corrado. The ABS master cylinder/pump goes south, this is a $1600 dealer part. There's your 2k estimate.
My wrench (NON dealer) suggested it would be possible to remove the ABS unit and replace with it with a master cylinder from a non-ABS car. He said it would be necessary to replace the brake lines as well. -d ------------------ Dave '72 911T to '73 RSR Replica Project |
A lot depends on what's gone bad. Could be something as simple as the ABS ring in a rear rotor, or as nasty as the computer (which could probably be found used).
Currently it should be in "fail safe" mode, which means normal braking, no ABS. Get a second opinion (probably non-dealer), and check at VWVortex. |
My other car is ‘96 Passat VR6 wagon. I never had any problems with the ABS though (actually I did not have any problems with this car at all).
Good place to check/ask is VW Passat owners group at http://www.geocities.com/MotorCity/1108/links.html If you disconnect the ABS pump you will also lose limited slip on the front wheels. It normally works by engaging brakes when the wheels start to lose traction. |
"If you disconnect the ABS pump you will also lose limited slip on the front wheels"
Good! It is a damn crutch for people who cannot drive! I hate traction control!!! Sorry for the rant ![]() |
to save money, why not try to find good used parts. There should be a ton of these cars that's been totaled by now.
Just my 2 cents Dave |
Senior Member
Hello
Had seen this problems on a german board and the conclusion was that VW, Opel & BMW had a high sensor failure rate "caused" by the sensor manufactorer. I think it hitet the 94-95 years. Some sensores can be fixed and reused. All ABS system have a falure safe setup and also most of them can read out the failure codes. Funny to replace it with a non ABS unit as thei will cost maybe more labour then to fix the system. And if your engine makes trouble I would sugest a squirrel wheel as a cheap replacment. Grüsse |
Or maybe even upgrade to the high performance "twin squirrel wheel" model.
![]() ------------------ Robert Stoll 83 SC 83 944 |
Senior Member
Hello
OK a 993 TT is a twin Turbo but a 993 TS a twin squirrel. In fact tost Porsche came as TS from the factory some have up to 3-6 SP ( squirrel power ), so a Six pack is the highest aviable power mode. Grüsse |
