-   -   915 INPUT shaft question (http://forums.pelicanparts.com/porsche-911-technical-forum/798165-915-input-shaft-question.html)
ray40 02-23-2014 02:26 PM
I have been rebuilding my 915 this winter using ZImmermans 9 part rebuild WIKI (yow)
question is this after reassembling input shaft and pressing things together I am noticing a slight amount of play between the (thrust?) washers and the 3rd and 4th gear stacks
maybe a few thousands or so.
Is that correct or do I need to crank up the press some more - so there is no play anywhere along the shaft?
much appreciated
