So I'm driving to work this morning when all of a sudden my 3.2 Carrera starts spitting and sputtering and finally quits altogether with a dead battery. After arranging for my wife to bring jumper cables, tow strap and extra charged battery to me and my dead car we discover that the "new" battery starts and runs the car just fine. After driving home I checked the voltage at the battery with the engine running. 12.09 volts. Okay, alternator is not charging.
I have searched the archives and have come across more than one post stating that if the charging system light does not come on with the key turned, which mine doesn't, then the charging system will not work at all since the alternator's pre-excitation field current is routed through this bulb. Question: Can someone better explain this? Could my whole charging problem really be as simple as a burned out bulb?
Nate Gone: '86 Carrera coupe Current: a $75 BMW 320i |
I am not sure if I can explain things much better. Here is a try:
In a nutshell the rotor is not a permanent magnet but an electromagnet with variable field strength. It produces a magnetic field by means of running a current through its coil. In a running and charging alternator the field coil gets its power from the stator coils by means of an rectifier array and the regulator. If you rotate this electromagnet without any field it will not induce anything in the stator coils - No output. To get the alternator to produce power you initially need to supply battery power to the field coil. This is done via the GEN light. Once this initial field powered by the battery induces some juice on the stator coils the alternator can sustain itself by using part of its output (D+) as field current supply DF. Some cars do have a resistor in parallel to the alternator light and should charge even with a burned bulb. Does this all make sense? Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Check the ground-cable between the battery and the body, se if there´s in bad shape and in that case just clean up the contact-areas on it.
I think you find your problem there. /Jocke
Jocke Andersson Reach me on ICQ - 317860713 Porsche 930 -77 SOLD Modified, one of a kind in Sweden. Check out my car @: http://members.cardomain.com/jocke |
Thanks. That makes sense. So the initial current through the bulb just get's the ball rolling, once the alternator is generating it's own current it doesn't need the current from the bulb so the bulb goes out.
It still seems odd that a $1.50 light bulb could bring my otherwise wonderful car to it's knees. Perhaps I ought to just accept it and move on. I'll check the ground strap too.
As Jocke said checking your ground and cable connections is always a good point to start. Ingo
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
Kurt,
I guess the concept of 'high-dollar' depends on whether you are selling a car ... or replacement parts!!! What does a replacement aluminum hood for an MGB go for, these days?
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Well, the light bulb was not the problem. The bulb was still good, just not lighting up when the key was turned on, or at any other time. Continuity from the bulb to the alternator was good and ground straps do not appear to be the issue. Wayne's book says the other options are a failed alternator or a voltage regulator for these symptoms. Sound right?
So the alternator is out of the car and will hopefully be checked out soon. The voltage regulator is internal to the alternator on my '86 right? Any competent auto electrical place ought to be able to check it out for me? Any other ideas?
Turns out it was a set of worn out brushes in my alternator. Sixty bucks to fix it. Gonna button it up and go for a drive as soon as I finish cleaning up the fan and shroud.
Black and Blue
Good troubleshooting. Im glad it worked out.
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
