-   -   Dumb question about pop off valve (http://forums.pelicanparts.com/porsche-911-technical-forum/79822-dumb-question-about-pop-off-valve.html)
hobieboy 09-06-2002 12:14 PM
I've read lots about pop off valve for CIS cars and even know how/where they fit in a normally aspirated cars.
But where does it fit for a 930? In fact, I remember reading somewhere that the turbo doesn't really need it.
So, what's the verdict?
thanks...
john walker's workshop 09-06-2002 12:25 PM
the turbo has a metal intake, not plastic like normally aspirated 911s 73-83, so if it did backfire, the intake would not blow up. the turbo HAS a pop off valve, but it is really a bypass valve that redirects air back around the turbo when the throttle is closed between shifts, so the boost pressure against the closed throttle doesn't stall the turbo.
hobieboy 09-06-2002 12:50 PM
John, thanks for the explanation...
It sounds like there is no need for a separate CIS pop off valve for the turbo then?
Any idea where is the bypass valve for the turbo?
