'73 911 T Targa
Cleaner to clean '73 MFI throttle bodies and air horns
I'm looking to clean age old carbon and crud from a set of '73 vintage throttle bodies and air horns. The throttle bodies are magnesium and only appear to have one plastic part which I have removed. The air horns are entirely plastic. The insides of the throttle bodies seem to have some heavy carbon deposits which have had decades to harden and adhere. What's the best solvent to go after this stuff with? I tried naphtha and it seemed to remove the general crud, but I'm down to stuff now that the naphtha doesn't seem to touch. 'Lil help please?
I tried every type of liquid cleaner beerman's, loctite, ultrasonic, Nothing has worked on the throttle plates. Maybe soda blasting would work?
Are the throttle bodies off the car and disassembled?
Cleaning........
Try spray paint stripper followed quickly by a water bath. I use this method for cleaning really dirty carburetor bodies that are heavily crudded up. A stiff bristle tooth brush will also help. Don't forget to wear gloves and eye protection.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
The factory manual shows Berryman's B-12 Chemtool being used to clear the TB adjustment screw ports with the engine in the car. We used it at the P-car school, and at the dealership where I worked. It may not work with the accumulation you have, but it did a pretty good job back in the day. For cleaning and preserving the mag surfaces, nothing beats "Gibbs Brand, which, when applied in liberal amounts over time, makes the mag look really nice. Hot rod and vintage racecar restorers use it for that. It's also a SERIOUS penetrant, better than Kroil.
The Cap'n Last edited by The cap'n; 05-27-2014 at 05:54 AM.. |
'73 911 T Targa
Yes, they're out of the car with the air horns separated from the throttle bodies and disassembled, except for the butterflies which are still attached. Looks like the screws that hold the butterflies on are staked.
Ultrasonic tank is the way to go.
I have an ultrasonic, cleaned them ok but the throttle plates are still not spotless. I am going to try soda blasting
I use Seafoam to clean up old spark plugs, maybe that will help.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
If you have time soak them in a bucket of Pine-Sol. Work wonders, won't damage anything and rinses off with out any toxic waste.
Caveman Hammer Mechanic
Get a gallon of Berrymans carb dip.
http://www.youtube.com/watch?v=bRiZOTTel34
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 05-27-2014 at 09:43 AM.. |
'73 911 T Targa
Do you think that either the PineSol or Carb Cleaner would soften or dissolve the plastic air horns?
Carb cleaner will melt most, if not all, plastics. This includes both the dips and the sprays. I have melted screwdriver handles to prove it.
The Cap'n |
DO NOT USE CARBURATOR CLEANER OR OTHER "Induction Cleaners" on anything plastic or phenolic. Soak the Throttle Bodies in undiluted Pine Sol and after a couple of days you can use an aerosol throttle body cleaner on the butterfly's with a tooth brush or other small bristle brush if needed. My only concern is after you have them clean will they need to have bushings for the throttle plates replaced? There are a few people out there that can rebush and set them up properly. That's a whole new thread.
The Cap'n |
83 911 Production Cab #10
Best cleaner and safe on all metal, plastic and paint;
Swish FACTO AT-30, see post 2 of http://forums.pelicanparts.com/cleaning-detailing-polishing/550748-best-cleaner-bar-none.html for detail and locations.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
$159, for a bucket of that?
No.... JR |
JR
In the US it should be around $100 for 20 liters pale, so its $5 a litter. Up here, we pay more even though its made here ![]() ![]()
