Plating my spring plates...
For one of my winter projects I decided to refresh the spring plates and replace the worn bushings on my ’87 Carrera. I want to re-plate the spring plates in yellow zinc, and have checked several platers in my area (northern Detroit suburbs). They all will plate them, but will not clean them up before hand; that’s my job. For those that have re-plated their spring plates, was there any issue plating the inside of the tube, down where the spline for the torsion bar is? Will aluminum oxide blast work in cleaning them up? The fit between the torsion bar and spring plate tube is so close I am paranoid about messing with this inside area. Did you do any special prep there? Any other words of wisdom in the whole process? TIA for the input…
Spline Fit
Can say that with my high mile 87 but very nice rust free southern car that I just did my spring plate bushings this past weekend. No re-plating for me, mine were just dirty, no rust at all. When we pulled them off, the torsion bars looked perfect and stayed in place, didn't move at all, even the grease on the T-bars looked new. I could feel that the inner spline wasn't stuck either. I'd say with mine, even thought the fit is good, its certainly no press fit. I'd block or cap the inner tube of the torsion plate and leave it alone if it was me. I used a 4" grinder and wire wheel to clean the outer surface of the old rubber. Worked fast and great. Last used the sandpaper provided by elephant with the bushings and a little brake cleaner prior to glue. Those surfaces looked perfect.
Thanks for the input. I was thinking about trying to block off the tubes also, as you suggest. Has anyone done this? I am no plating expert, but can you just plug the end with a rubber plug prior to plating?
.Thanks for the encouragement. I do tend to be a bit over cautious. Ok; I'm going to clean and plate everything. I took off the rubber bushings and wire brushed and sanded the tubes. It's clear I had to go well into the plating for that, so I need to plate. Gonna do the whole shebang...
just for anyone else who comes across this, when you plate these parts the zinc only goes inside the tube an inch or so. Some kind of science reason for that. But the splines don't get touched. No where near.
| All times are GMT -8. The time now is 01:37 AM. |
