steeler1
Question 7x16 Fuch front wheels
I have a 1989 911 Carrera with 6x16 on the front 8x16 on the rear I like the look of the 7x16 deeper look in the front I've been doing research on the Internet I found that there are different models of the 7x16 early, late and ones that were on the 944's The ones that I'm looking to buy are the late model 911.362.115 are these going to fit on the front Thanks
these will fit fine, but you may need to roll your front fenders/etc. to eliminate rubbing on the outside of your front tires (assuming you don't have a turbo-look)
As darrin said, these will fit fine.The ET is 23.3 which is factory sized for the front of a 911.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Rescuer of old cars
And if the goal is the deeper look, you want the 911 16x7, not the 944/951 wheels which will fit the same but look like your 6" but with recessed lugs.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
