68 Chain Tensioner
I have a 68 2.0S engine I pulled this winter to check the chain tensioners. It has the 930 style tensioners with collars, I will rebuild these. It was recommended that I change my narrow idler sprocket arm and non-bushed sprocket for later styles. The set up now has the spacers. I have been unable to find these parts at a reasonable price, I know they are available new but costly. All the parts show very little wear. Should I just re-use these and call it a day, is it really necessary to replace the arm and sprocket. The car will not be tracked and may get 3k miles per year of street use. Opinions?
Old 03-29-2014, 04:48 AM
Supertec can modify your narrow idlers to be wide with a custom bushing.
andy
Old 03-29-2014, 05:20 AM
Thanks, are there any other options.
Old 03-30-2014, 05:25 AM
