jwakil's Avatar
Leak down on a cold engine
I know that the procedure for a leak down test is to do it on a warm engine. However, I will have the engine partially out, and obviously not warm. Should there be a big difference in leak down results? Should I expect better or worse results when cold?
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 03-14-2014, 02:26 PM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
Worse when cold. But probably not by a huge margin. What you really want to look for, just as when hot, are large deviations between cylinders vs. the overall leakdown %. From what I have seen, less than 8% is great. 10-12% when cold might be a what I would consider acceptable. I am no expert in this matter though--interested to see what other have to say.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 03-14-2014, 02:31 PM
Functionista
manbridge 74's Avatar
Consider removing plug for each cyl AFTER it is at TDC so as not to get any carbon between exh valve and seat skewing numbers.
I like to do leakdown cold and comp test hot and compare numbers afterwards, noting any inconsistency in results.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 03-14-2014, 07:19 PM
