-   -   Running Badly Please Help (http://forums.pelicanparts.com/porsche-911-technical-forum/799499-running-badly-please-help.html)
jaubuchon 03-03-2014 07:34 PM
87 911 3.2 cabrio widebody, autothority maf, no cat.
My car is horribly running, rough, low on power from 2k to 3k then 35 to 4k but then it clears, done a cap, rotor, 02 sensor, all fuel system gone over, alarm removed, tank cleaned, plugs, alternator checked out, not sure where to go now.:confused:
Please help
boss11 03-03-2014 07:39 PM
ignition leads?
jaubuchon 03-03-2014 08:19 PM
nope
Originally Posted by boss11 (Post 7942602)
ignition leads?
all ohm ed within range
ischmitz 03-03-2014 08:31 PM
Does it have the stock barn-door AFM or an aftermarket conversion with hot-film sensor and modified DME? I assume it's the later when you say Autothority. I believe the kit is a modified chip (accounts for the different response function of MAF), a hack in the DME (power to the MAF) and the MAF itself.
Then your Garage says it has an electric Turbo?! - can you elaborate
What changed or was it always running terrible like this?
Was the change gradual or sudden?
Do you have the stock parts and can you put them back? (you need a stock DME & AFM)
If not my first guess would be something on the conversion went bad and you are stuck with replacing it on a hunch. The filament in these sensors can become contaminated with time giving wrong readings. Depending on the model used some have a self-cleaning function (heat up wire real high on start to evaporate contaminants) but others don't.
Not a good position to be in....
Next the usual suspect that affects mixture: vacuum leaks.
Ingo
jaubuchon 03-03-2014 08:35 PM
Ingo
Maf, runs bad with or without turbo, just started running bad one day, dont have stock parts bought already converted, done vacuum checks
jaubuchon 03-03-2014 10:40 PM
So does anybody have any more ideas as to what it could be, i'm getting to the point where i'll take it to the crooks in town at the porsche shop:confused:
snbush67 03-03-2014 11:35 PM
Double check you plug wires and firing order.
jaubuchon 03-03-2014 11:38 PM
did already unfortunately
DCinVA 03-04-2014 01:52 AM
Check the idle microswitch. Its located on the throttle body, and it tells the DME that the throttle is closed. Sometimes when they go bad, they get stuck in throttle closed mode, effectively telling the DME the throttle is closed, even though you are pushing on the pedal. I believe the WOT switch overrides the idle switch. How does it run under Wide Open Throttle?
The classic symptoms of a bad idle microswitch are.
Engine idles fine.
Engine runs fine at Wide Open Throttle.
Any other throttle position results in bucking, running rough.
jaubuchon 03-04-2014 08:16 AM
Engine idles fine.
Thank you I will try that
Nuen Werke 03-04-2014 11:15 AM
coil?
DCinVA 03-04-2014 01:12 PM
Here is a simple test for the secondary wiring (plug and coil wires).
Wait till dark.
Turn off all the lights.
Open engine lid.
Fire up engine.
Visually inspect for small lightning bolts.
If you see any sparks at all, replace the secondary wires.
