Wayne, Sell the float gauge?
Wayne,
First off, thanks for the greatest online Porsche catalog and message forum. I visit it everyday. Why don't you sell the Weber and Zenith float level gauge? Why doesn't anybody make one and sell it cheaper than $50? Why do I have a 70T and now want an SC? Why are we here? Ok......enough .....what about the float level gauge? Must I purchase at the other guys? I don't want to. Thanks, Scott |
Senior Member
Re: Wayne, Sell the float gauge?
Who could blame you for wanting a far better car?
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Author of "101 Projects"
Float level gauge? For adjusting the height of the floats? Just use a caliper, like the directions show in 101 Projects?
Or perhaps I don't completely understand. We do sell the tuning tool for calibrating the air flow... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Senior Member
Wayne,
There is a special tool, believe P226 is the part number. PMO used to sell them. They are screwed in the side of the carb float bowl and gives you an exact level of the fuel, not the float, in the carb. Its really a must if you are going to get a set of webers working correctly. I made my own but its a jury rig situation because I could not get one for under $100 while living overseas. Can be done if you are handy with tools but it also would be nice if you guys could sell them as well. Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Re: Re: Wayne, Sell the float gauge?
I want an SC in addition to my classic. If I had to choose one......... well ,I guess I already have
Hopefully I can choose two!The reason one really needs a float level gauge is someone could have in the past used one and adjusted the float level by bending the little tab on the floats that contact the fuel inlet valve to obtain the correct fuel level rather than adding or subtracting washers under the valve. This throws off any measuring of any float to carb body measurement method described in some manuals. This scenerio happened to me on a couple of carbs years ago rebuilding some carbs (Zenith or Webers?). The 2 floats had the tabs in different positions, so I didn't know which was correct. Only a fuel level measurement via the external gauge as the car was running seemed reliable. Quote:
Senior Member
Scott,
You cannot get a good idle without having the fuel level set accurately and equal in all of the carbs. I battled it for months before making the gauge and it really helped. Also, the fuel level also effects the mixture as a higher fuel level puts more head pressure and you get a richer mix on that one throat. Joe
I know this all too well. It wasn't long before I purchased the gauge. It is lost now and I really don't want to pay $50 for that little thing again, so I am going to make one also. I would purchase one for a reasonable price.
