Under dash wiring plugs/recepticals
HELP. Just replaced the ignition switch in an 87 911. In the process I unplugged four under dash wiring plugs. One was a five pole but all others were identical round 6 pole plugs. I cannot remember where they go. Two come from the steering col. and one from the ignition. Ther are three receptical in a row and one just above the ignition switch. PLEASE tell me which one goes where. A quick look under the driver's side dash should do it.
Thanks!!!!!!! And please don't try this yourself. :-)
Larry
Old 09-07-2002, 06:39 PM
cary's Avatar
Best I can tell..........
Left one......steering column. Light switch side
Middle one....steering column. Wiper side.
Right one. Ignition switch.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 09-07-2002, 08:19 PM
Senior Member
Hello
Look for littkle color dots on the connectors and on the bases on the firewall.
You should find blue, green and yellow dots.
If not just messure the paths.
AFIR the outhers are wiper the middle is light and the inner is ignition
Abouve the switch should be light from the switch, hazard, light from the stalk.
Just wait a sec on your year the hazard was moved to the centerconsule.
Grüsse
Old 09-08-2002, 04:16 PM
