toddu's Avatar
Tight radius hose sourrce
Due to where my oil breather catch can is and the angle of the fitting on the oil tank fill neck, I'm going to need hose that is capable of a tighter radius than the thick stock crank case breather hose.
Anyone have tips on where to look? I've been scouring the internet, but nothing so far (well without ordering some and taking a chance it will work).
Todd
'81 SC
Old 03-04-2014, 06:47 AM
Slippery Slope Victim
NY65912's Avatar
I remember seeing tight bend small diameter hoses at your FLAPS for heater connections.
MikeČ
1985 M491
Old 03-04-2014, 06:49 AM
Banned
juanbenae's Avatar
i had the same issue at one time with my added front cooler with rubber hoses and adding a hose clamp at the pinch/bend point will keep the hose from pinching/crimping keeping it round. it may not serve your needs visually, but it is affective.
Old 03-04-2014, 08:31 AM
How about an angled/radiused fitting?
Art
'75 911 US Carrera #390
'74 MGB, AH 3000 BN7 V8,
'65 Mustang Fastback, 66 bronco U13
Old 03-04-2014, 09:43 AM
gptom's Avatar
Install a spring inside the hose. It will prevent kinking
Tom
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 03-04-2014, 11:07 AM
toddu's Avatar
Tom
The issue is finding a hose that is flexible enough. There's a motorsports place not far from my house. I'm going to stop in there and see if they have any thoughts.
Todd
'81 SC
Old 03-04-2014, 11:26 AM
OffCamber00's Avatar
Todd - I used a section of the old breather hose that went from the oil tank to the back of the intake boot. It has the correct radius in there to work.
Mat P
1988 911 Carrera
Old 03-04-2014, 11:37 AM
toddu's Avatar
Hmmm, yeah, I might have to see what I've got laying around from what I took off. Thanks Mat! I should be ready for next cars and coffee!
Todd
'81 SC
Old 03-04-2014, 11:41 AM
BoxsterGT's Avatar
Porsche Crest
+1 on the coil spring inside the hose. Especially when this is a breather hose. Cheap & easy.
Len
Old 03-04-2014, 03:04 PM
walt's Avatar
McMaster Carr lists bend radius for all their hoses. Look for one oil and fuel resistant.
Walt
Walt
82SC 3.0
81SC 3.6
Old 03-04-2014, 03:09 PM
NY65912's Avatar
http://images.oreillyauto.com/parts/img/medium/gat/18423-1.jpg
MikeČ
1985 M491
Old 03-04-2014, 04:21 PM
Don't laugh..I used a clothes washer drain hose once for connecting a catch can. Worked well and was cheap
1986 3.2 Carrera
Old 03-05-2014, 04:28 PM
toddu's Avatar
Looks like the easiest solution is going to cut the bracket I made and weld in another 1.5 inch section. Should get be high enough where the hose should fit with a minor struggle.
Todd
'81 SC
Old 03-05-2014, 05:05 PM
haycait911's Avatar
Tom
yup.
Old 03-05-2014, 10:42 PM
Wer bremst verliert
JohnJL's Avatar
i cut a straight aluminum hose fitting like the black plastic oem one and welded it back together on a 45 degree angle. that allowed me to route that breather hose down and around the peri eter of the engine bay for a very clean installation.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-06-2014, 04:11 AM
I also vote for window shopping at a FLAPS. They should also have hose catalogs you can look through to find a suitable fit. Fitting a spring into a hose, then bending it to fit will work for awhile, but that puts stress on the hose material which will eventually fail (crack). Fit that spring into a hose shape closer to the final radius.
Sherwood
Old 03-06-2014, 02:53 PM
