Cutting Correct 911R/ST Rear Exhaust Bumper Holes??
Ok, this is probably going to sound a little neurotic...
![]() I have a 911R rear bumper and I want to cut the correct shape and size rear exhaust openings to replicate the factory openings on an ST or R rear bumper. It seems they are somewhat oversized and are not a perfect half circle (or maybe its an illusion due to the curve of the rear valance). Any ideas/tricks before I start hacking away to get it right?? Thanks!
Anyone?
I would rather be driving
I cut mine as close as possible until the bumper and muffler both fit while still touching. Then I used a spacer block and a marker to trace a concentric arc around the exhaust pipe.
Then I cut the line using a coping saw. Then sand the lip to profile finish, prime and paint. This way you account for any manufacturing differences in the muffler pipe locations.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I have an RSR bumper and the exhaust holes are molded into it. Just needed to be cut out. When and if you do cut mask with nice blue painters tape and use a new blade in a nice body saw. It will cut like butter. Use a file or sandpaper to clean up the edge when finished. Good Luck.
Thanks guys! Tocobill any chance I can get some basic measurements height and width of one of the holes??? Much appreciated!
Yep, Give me a coulpe days. I just got back from sea. I should be over at my shop over the weekend and I can grab some pics and measurements for you.
Yes, but if you really want to be exact, find an original R and take measurements. All other replicants are approximations, some closer than others.
Are there concours events for tribute cars (clones)? Sherwood |
hehehe ... I can see the reaction on the owners face when you break out a tape measure and start to measure the hole in there bumpers, lol.
Okay JP...say that again!
Bavaria911 1970 911T w/ 2.4S 1971 911T Targa w/ 2.2 RG Member # 818 |
Thanks TocoBill!
Maybe I need to start locating the nearest R or ST and bring a ski mask and a tape measure! ![]() ...now that's Neurotic! |
Snapper ... I made a template up with tape and outlined the contour of the exhaust hole on my rsr bumper. I havent cut mine yet. There is a bit of a radius that drops into the hole. I used a marker to trace the lower inner radius. Just line up the two hash marks with your bumperette and the lower line with the lower mark. PM me an address and Ill mail it to you.
Thanks Tocobill!!
Another example of why this forum rocks
