Kartoffelkopf
964 Inner Wheelarches - Correct factory finish?
Hi Guys,
This weekend, with the eventual break in the foul wet weather, I rolled the car out to start cleaning up the chassis in preparation for putting the engine/gbox back in. First job was to clean up the rear inner arches. I got all the grime off, no problem, however, what I was expecting to see was the body coloured stonechip paint finish on the inner arch (ie the tub). What I actually got was a black "top coat"and it seems to extend beyond the plastic inner arch liners. Where I've been scrubbing (mainly using Bilberry wheel cleaner until I ran out...) it has removed some of the black coating to reveal the original body coloured paint stone resistant paint underneath. So....for a MY 1992 964 Turbo, does anyone know what the factory finish should be? From what I've seen on other 964 & 993 build threads I'm sure it shouldn't be black....but you never know. Or has a previous owner had this applied quite diligently, ie they went to the trouble of removing the plastic inner arches.... And what would you guys do next? I'm not at all confident that I can get it all off satisfactorily, to make it look good. Should I just buy some good quality protective paint like this Dinitrol and re-apply to both protect and smarten up? Apologies for posting in this forum versus the 964 one....just a bit tumbleweedy over there! ![]() Thanks in advance folks Spencer.
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject |
I believe the factory used a tintable Wurth rubberized coating, but I'm not sure how well it will stick to a previous cured surface of itself, let alone the black top coat. Usually the top coats are petroleum based so a petroleum based solvent should remove it with a little elbow grease otherwise scuff it up a bit so whatever you apply has something to grab on to.
the tub should be body color, inside of fenders just satin black paint.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Kartoffelkopf
There's a hell of a lot of it to get off, and I have to wonder that with the damp UK climate, a good re-application of black Dinitrol to protect the tub may be a better (albeit not factory original) option. First job - get everything thoroughly cleaned and degreased. Coming along nicely, but going to ache like a ***** tomorrow, all sorts of strange upside down contorted angles going on! Cheers Spencer
Kartoffelkopf
![]() It does look very much like a factory application; no runs and once washed it's a high gloss finish. If it has been applied after the car was built, then somebody has done a proper job and removed all the ancilliaries and rubber grommets first. Even the access hatch on the RH side footwell is bright and plated, no overspray; I stripped the oil cooler and pipes out over a year ago for the engine project, and there weren't any signs of waxy overspray. On the other hand, if it was a factory coating, then surely the underside of the floorpan would also be black? It's not, it's the standard dusty beige colour. ![]() Here's the rear arches, showing what I managed to clean off over the weekend --> ![]() ![]() So, although I agree, a factory stock colour would be nice to see under there, unless I can buy the solvent that is specifically meant to remove this (I'll speak to Rejel tomorrow, who re-sell the Dinitrol range), I don't think it's possible to get it cleaned up well enough to look "stock"....that'll happen in "X" years time when a full strip, dip and respray will inevitably need doing! Anyway, this car's so far from being stock it's not funny....what's one more item that's custom, eh?
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject Last edited by Spenny_b; 02-24-2014 at 04:25 PM.. |
Funnily enough, I cleaned my arches a few weeks ago, and came upon the same black paint, which came off with vigourous cleaning with brake cleaner, to leave the blue paint over the shutz. A clean up i could manage, but not stripping off the paint everywhere. Once clean puffed a bit of Wurth satin black back over the bits I went mad on!
