Charles Freeborn's Avatar
Quickie Fuchs Refurb
So all you q tip warriors can go, well, do what you do, but for the rest of us here's how I took a pair of wrecking yard Fuchs and cleaned them up. Total time is about an hour and a half per wheel. That said - I use power tools for a living so there's some operator experience going on here.
Step one - using an angle grinder slowed down to lowest speed and a foam backed hook and loop 500 grit pad knock off the worst of it. Use soapy water for lube.
Then switch to a cotton buffing wheel in a right angle die grinder. Use Flitz polish with more soapy water to keep it all nice and gooey.
To get the inside bits use a dremel with a cotton buffing wheel
Then some rattle can semi gloss clear to match the look of OEM anodizing. Bottle caps make nice plugs to keep the spray paint out of the lug holes.
And voila! clean hoopdies
2 wheels -about 3 hours. Not concours, but for a set of track wheels not too dang bad.
-C
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 03-15-2014, 10:03 PM
Uncertifiable!!!
Uwon's Avatar
Charles, nice job! Thanks for posting.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 03-16-2014, 04:08 AM
Caledonian's Avatar
Love the "q tip warriors" bit
Old 03-16-2014, 05:38 AM
