KS Roadrunner
koenig911's Avatar
Question RUF Fuel Enrichment
Does anyone know how RUF increased fuel by using a pressure regulator installed between the warm up regulator and the top of the fuel distributor? This was used in the RUF BTR upgrade. If you check Bruce Anderson's book there is a pic of the BTR kit and to the right you can see the regulator.
I assume this changes the control pressure. Typically you reduce the control pressure to richen the fuel mixture. However, how does this regulator reduce the control pressure? It has no vacuum line to sense boost and has and adjustment screw at the top. I would expect that it can only increase the control pressure by restricting the flow from the fuel distributor to the warm up regulator.
Also why is this not commonly used? As compared the the Andial and 7th injector mods?
Old 09-09-2001, 12:11 PM
Post
I would also like to know how this was accomplished.
Old 09-09-2001, 01:58 PM
KS Roadrunner
koenig911's Avatar
Post
AMG,
If I recall you had a modified 930 with electromotive, twin plugged and oversize intercooler. Do you have this regulator installed on your car also?
Old 09-09-2001, 02:20 PM
Post
Koenig,
I had a Miller Woods 7th injector, I've since removed this item. Many people insist this isn't a viable solution to properly enrich fuel. I do have the Euro CIS though.
I will do some research on the RUF mod. I thought on the BTR he used a different fuel system all together.
Old 09-09-2001, 04:54 PM
