Yes that is Pasha cloth
hard shifting with a back seat full of girls
Last night went to dinner with friends. Friends wife wanted to ride in the shiny red car. The wives are small enough to fit in the back seat so off we went.
In addition to some wheel rub from the 255/17's I noticed a real difficulty shifting into first. I have been chasing the stiff shifting in 1-2 since I got the car. Replaced shift bushings and used the coupling whisperer bushings for the coupler. While better it still isn't guaranteed to shift in to first at every attempt. Then last night was the first time I've had people in the back seat. So any idea what the new symptom might be telling me? I figure on trying to adjust the coupler once again. FWIW, first time I jacked up the rear of the car, I did notice that the engine mounts seemed good. No play between when the engine started lifting and the rear of the car did too.
84 RoW, slicktop coupe, with Pascha baby! 08 GTS Cayenne |
El Duderino
Tranny mounts?
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Banned
Reiver
UnRegistered User
Little coffee out the shnoz!
El Duderino
Guess I walked right into that one... Well played!
There might be some body flex with the additional live load.
The flex could cause amounts of misalignment in the shifting assembly. More likely is the transmission changing position because of the added stress/weight. I would look at transmission mounts. Also look at your rear drop links, one of mine was disconnected, which lead to me replacing both. The sway wasn't really noticeably unless I had passengers in the back, or a heavy dude in the front. This however never affected the shifting.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Tranny Mounts, He said tranny mounts, he he he.
OK I guess I have an issue with shifter alignment so I'll look into that.
With a nod of respect and a polite golf-clap of approval toward the most excellent tranny remark (smirk-smirk), I would also suggest that the mounts could be the focus here. I changed the mounts in my 87 a couple of years ago and I swear I could feel a slight improvement. I was wondering if the vertical alignment had anything to do with it.
As a test, I suppose to you could remove the rear tunnel coupler cover, and load up the weight in the back seat to see if the coupler/shaft was raised or rubbing against the body. When you jacked things up, you kind of removed the issue, so the problem might not be visible anymore.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Banned
Banned
muck-raker
if I had a back seat full of women, I would gladly take the stiff shift trade-off.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
I think we need pics of the cargo to determine the issue.
92 964 RSRish project 01 996TT 95 325i 92 318i etc, etc, etc |
Banned
Heck I have two bathtubs full of pills and it was not quite enough to make things shift into the next gear.
![]() But this is my half of the load in the backseat.
Not too bad for an old guy like me.
So you had trouble getting it into first?
I think I'd have hopped into the back with the girls and tried to get it in. |
Banned
Not that I want to start a fight in your house...but...could you perhaps suggest the "girls" need to diet a little? .... LOL
Bob
Bob Hutson |
Banned
Ha - right, a 911 full of wemmens (that actually fit in the back of a 911) = more than just a stiff shifter I would think!
