Trying to ID Engine by Sedrial numbers..Need Help
Hello,
I have 2 engine and here are the numbers.. 1. Believed to be a 2.0 T engine- 606161809 2. Believed to be a 75 2.7-on the fan shroud 901 106 101 5r . next to the fan stamped in the alunimum *6146279* . and on the bottom of the block i found 901 101 102 7r Thanks A bunch, ROn |
Hi Ron,
Your first engine number has to many digits.. it should be 7 digits and you have 9 might want to llok again. the second engine number: 6-1-4- 6279 breaks down as follows, 6, 6 cylinder 1, 911 4, 1974 6279, Sequential numbers and the numbers on the bottom, I believe are part number for a R spec case. Thats about all I can decifer.. Jorge (Targa Dude):cool: |
Just wanted to throw one more thing out there on the 74' 2.7 motor
614**** (6), 6 cylinder (1), Engine type. 1 base model. (It used to stand for T in the previous year. 2 was an E and 3 was an S in 73'). In 74' 1 is base model, 3 was an S or US Carrera, and 6 was a Euro Carrera as in MFI. (4) Year. |
| All times are GMT -8. The time now is 09:42 AM. |
