sp_cs's Avatar
Clutch gone?
Gents,
On a recent 'enthusiastic' run, i was in 2nd at approx 4k rpm waiting for an overtaking opportunity for about 15 secs; when this arrived, I changed up from 2nd to 3rd at approx 5-5.5k rpm. All appeared to be fine....
Im now finding there's a fair bit of juddering when moving away from standstill in 1st and reversing - i've let it sit for 5 days without use and its still the same.
Clutch has circa 40k on it (sachs spring centred disc with KEP ally housing), with a fair chunk of stop/start traffic
Would be par for the course for me to need a new clutch, however is it more likely to be disc or housing related? Or something else that would cause the judder?
SP
Shirish
1987 Carrera, Granite Green
Old 03-21-2014, 02:20 PM
French Import
zippy_gg's Avatar
I would start by checking engine and transmission mounts for wear and tear, and also to check their torque before embarking on a larger troubleshooting effort.
Fingers crossed!!!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 03-21-2014, 04:28 PM
T77911S's Avatar
check mounts as mentioned.
you may have "hot spotted" the clutch or flywheel.
my 930 did/does it when i bought it. i just had to adjust how i took off from a start. i have not really noticed it in a while.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-24-2014, 02:56 AM
sp_cs's Avatar
Thanks both - if it is the clutch is it likely to be the clutch disc, housing, flywheel or all three.
If the clutch is at fault, tempted now to replace with a standard clutch, especially if the KEP pressure plate has to be changed
Old 03-24-2014, 08:09 AM
