Spring cleaning tips?
Winter in NE has finally seemed to turn the corner (and my garage is above freezing) so I've started a few small projects to get ready for the spring. In the process, I've noticed the nooks and crannies are pretty darn dirty (mostly road gunk, etc.).
Any tips for cleaning this type of grime off - what to use/not use, what's worked well for you? Pressure wash? cleaners?
Thanks!
Old 03-19-2014, 12:33 PM
I'd use a plastic scraper for that mess, followed by a brush with some simple green, then hit it with a rag and a little more simple green.
I have a small garage so I don't get too crazy with caustic chemicals like carb or brake cleaner.
1982 911 Targa, 3.0L ROW with Webers
Old 03-19-2014, 12:39 PM
Senior Member
Jdub's Avatar
Be excellent to those wires - remove them prior to cleaning and tuck them away. Any time you spend removing gunk from any hot oil-containing item (oil cooler, oil tank, etc.) is time well spent.
As above on removing the gunk. Do this over a tarp and throw the results into the garbage, not your local water system. When done Gumout or similar on the wire contacts and carefully reattach.
'78 Targa in Minerva Blue
Old 03-19-2014, 01:39 PM
redridge's Avatar
If you are gonna put fresh oil I would just pull it out and go for it... I used POR15 with an undercoat for extra protection. Also put in a new gasket and a new rubber cap for the electrical.
Old 03-19-2014, 02:19 PM
Fleabit peanut monkey
Bob Kontak's Avatar
In that wheel well, I would schlep it over to the $2 pressure washer, pull the wheel, Gunk it to death and blast away.
These are not girlie girl cars. They can take it.
NO for inside the engine compartment. Old school electrical connections. Not so in the wheel wells.
1981 911SC Targa
Old 03-19-2014, 02:53 PM
thanks
Nice pic redridge....now I have something to shoot for!
Old 03-19-2014, 02:54 PM
Bob Kontak's Avatar
POR15 is awesome if you wanna pull the tank. Spend $20 to hot tank it an put in a new sender/gasket (While you're in there).
Low cost restoration.
1981 911SC Targa
Old 03-19-2014, 03:00 PM
