kplackmeyer's Avatar
2014 911 GT3 recall
Ouch...
Apparently the connecting rod fastener has failed in 2 cars causing fires. They will replace the engines in all 2014 GT3s.
I would be happy to take a "bad" one off their hands.
Porsche to replace recalled 911 GT3's engine
Kerry Plackmeyer
1975 911s
Old 03-19-2014, 04:49 PM
This is so funny. Only two fires and they're doing a recall. Safety issue??? What about all those poor bastards with 6gt3's and 6tt's with failing coolant lines?? And how about the unlucky owners of 997.1S's with scored p/c's. ===Dchunk...
Why doesn't Porsche help these guys??
Pretty fkd up if you ask me.
Old 03-19-2014, 05:38 PM
Metal Guru
911nut's Avatar
Fires (or anything that could cause fatalities) generally get a manufacturer a lot of unwelcome attention from governments so I'd expect Porsche would be all over it. As for all the other warranty issues, Porsche has d1cked a lot of owners. Yet, there doesn't seem to be any shortage of people willing to part with their money for a Porsche. That's what I call Brand Power....
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 03-19-2014, 06:47 PM
Undocumented User
McLaren-TAG's Avatar
It's easier to do that when to date they've sold just 164 991 GT3s globally.
Old 03-20-2014, 05:45 AM
redridge's Avatar
there you go, 164 isnt all that bad.... compared to what GM and Toyota had to deal with lately.
Old 03-20-2014, 07:05 AM
Wer bremst verliert
JohnJL's Avatar
Its all about context...GM is being raked over the coals for lackidaisical handling of recalls, so Porsche can easily differentiate themselves with an announcement like this for relatively low cost.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-20-2014, 07:07 AM
Taking it apart is easy
Jerome74911S's Avatar
Porsche will take those 164 'bad' engines and fix them. Then install them into new GT3s after a complete check-over. Cost is minimal, but PR is significant.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 03-20-2014, 08:41 AM
petevb's Avatar
A bad batch of bolts on con rods allowed the pistons to separate from the rods. This in turn let the rods to punch through the side of the block, causing fires in two cases, simply eating motors in others. Failures were very rapid, within hundreds of miles in some cases.
The early failures made headlines- Richard Hammond of top gear owns one, and they made it a running joke, giving him oven mitts a Porsche emblem, etc. Top Gear goes out to 750 million viewers a week, so the publicity has been far less than ideal. Exactly how many fewer Cayannes, Panameras, etc were sold as a result is difficult to calculate.
Porsche will replace the motors in the ~750 GT3s built so far, and seems likely to extend the warranty on at least the 2014 cars. As the GT3s warranty covers track use (with some caveats) this could end up being very valuable.
Exactly how Porsche's extensive test program missed the issue isn't yet clear, and a few other failures (cam sensors, etc) have also been noted. Long term durability of this new motor is TBD, we'll see. Reports so far are that motorsports has been unable to make it as durable as the Mezger, which is why the Cup cars haven't switched over yet.
69 w 997 GT3 3.6L
Old 03-20-2014, 01:40 PM
Synchro Joe's Avatar
GT-3 Fires
Don't imagine the optional factory fire extinguishers would suffice in these cases.
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you.
Old 03-20-2014, 05:27 PM
