-   -   Heat exchanger removal tip (http://forums.pelicanparts.com/porsche-911-technical-forum/8022-heat-exchanger-removal-tip.html)
danielt 09-09-2001 08:59 PM
Just removed both heat exchangers on 1981SC with 100K+ miles. If you round one of the 13mm nuts, you can use a 1/2" hex socket with a 1/4" ratchet to remove the rounded nut. After heating the nut several times, it came off quite easy even with the small ratchet.
