Oil pipes
Hi folks, i have an 83 SC. The oil pipes in the front wheel well seem to sit very tight to inner wing - they press against the two "ribs" which you see when you look towards back of car while under wheel arch. I'm convinced it's wearing the underseal away.
They seem to be as high as possible. Any tricks for getting them higher? Can't see a way to push up or an adjust area.
Thanks a million
Old 03-23-2014, 05:19 PM
toddu's Avatar
Those don't move, etc. so should not be causing any wear. There is a "pocket" where they sit into.
Todd
'81 SC
Old 03-23-2014, 05:27 PM
