G50911's Avatar
Help - Rod knock?
Posted this in the engine rebuild forum but also want to post here for more coverage.
Help with knock noise
1967 911 (Azzuro Thetys) - #308439
1971 911 (PTS Black) - Built 3.6 Sleeper
1989 911 (Grand Prix White) - Cabriolet Bone Stock
Old 03-24-2014, 12:27 PM
Banned
That's definitely not rod knock - rod knock is a much deeper, "thunk" sound, does not go away with heat, and gets much worse very quickly. It's obviously difficult to diagnose engine noises on these cars, particularly over the internet, but that sounds like an exhaust leak to me (maybe at one of the header flanges?), or a compression leak due to a broken head stud.
Old 03-24-2014, 12:33 PM
Reiver
Reiver's Avatar
Sounds like piston slap...if you have forged pistons (Nikasils) you can get that sound. It will quiet down when warm. V8's with FP's really sound off when cold.
Rod Knock does not go away when warm.
Old 03-24-2014, 01:12 PM
No clue on the sound. BUT sweet engine bay!!
Old 03-24-2014, 01:43 PM
Make America Great Again!
Rich Gas's Avatar
Lot of times it's just the fan hitting the housing, because of over tightening of the strap. Take the fan belt off and give it a try.
Old 03-24-2014, 01:55 PM
Reiver
Reiver's Avatar
Too slow to be the fan, my euro 3.0 with Nikies makes a very similar noise and has for thousands of miles.
Louder when cold, quieter when warm...goes away under acceleration and can be heard warm at idle...piston slap.
Hope that's the issue as it's really not an issue.
Old 03-24-2014, 02:09 PM
pors1968's Avatar
I would recheck valve ajustement
Old 03-24-2014, 04:40 PM
G50911's Avatar
i just heard back from the shop and looks like cylinder #2's compression is super low (~70). going to check the valves in that bank tomorrow and see what could be going on. i hope it's nothing more than stuck valves...
Old 03-24-2014, 05:48 PM
Under the radar
Trackrash's Avatar
You can isolate where the noise is coming from using a stethoscope. They are inexpensive at HF.
Put the car on some secure jack stands or a lift, and get under the motor when it is running using the stethoscope to pinpoint where the noise is coming from.
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-24-2014, 05:52 PM
Banned
Not to be Mr. Negative, but with that noise, and now the poor compression number, I bet they will find two or more broken head studs on that cylinder.
Old 03-24-2014, 06:11 PM
G50911's Avatar
don't jinx me now!
man i hope not. i just dropped the motor less than 3 weeks ago. i'd hate to have to do it again.
Old 03-24-2014, 06:19 PM
G50911's Avatar
so quick update... no broken studs. just tight valves. i just got this valve job done less than a month ago so pretty disappointed with the other wrench but glad i found a new one.
re-adjusted and now getting 150lbs!
other valves in same bank are off too. going to do the other side now just in case.
Old 03-25-2014, 03:42 PM
Reiver
Reiver's Avatar
that also cleared the noise issue?
Old 03-25-2014, 03:48 PM
pors1968's Avatar
It happen to me with2.4 new valve guide ajust valve and after 10minutes poor running and same knock 50 psi had bent valve but your came back 150psi add some oil aditif and let run idle because next time temp goes up you wont be lucky.That why i said recheck valve ajustement.
Old 03-25-2014, 05:17 PM
