911SC / 930 Bolt pattern - help
Can some one tell me what the distance is from the brake caliper mounting holes, to the center of the rotor ? ( eventually the pitch circle)
911SC front ___mm ? 911SC rear ___ mm ? 930 3,3 rear ___ mm ? Thanks Roslinhttp://forums.pelicanparts.com/uploa...1395862987.jpg |
rotor radius plus or minus the spacing of the bolt holes from the edge of the rotor. easy.
you are right John - this is an easy way to find the dimensions, but the car is not disassembled yet, and i do not have a 930 car. I was just playing with a new idea on my computer, so if anyone have these dimensions on a sketch - especially from the 930 rear, it would be a great help.
I have seen some drawings on newer Brembo calipers, where all the mounting dimensions are shown. Thanks Roslin |
| All times are GMT -8. The time now is 02:06 PM. |
