Tie Rod Question
I took my 83 sc for an inspection sticker yesterday. The technician couldn't get my car to roll to save his life. He stalled it about 10 times with lots of bucking. He grind the starter twice and also my reverse gear. I was horrified watching him try to pull it into the garage bay.
Once inside, he checked all the lights and then proceeded to roll his jack under the side of the car! It's a good thing I was out there watching and stopped him. He said he would not pass my car if he couldn't jack it up and check the front end. So, I pulled out the jack pad and let him lift each side. There was a slight side to side motion on the passenger front wheel. The technician immediately said, I can't pass this, the inner tie rod end is bad. He checked the other side for completeness and said that one was fine. So, I have a big "R" sticker now. When I got home I lifted the car and checked both sides. The slight movement feels the same to me. But I am not a mechanic. My question, is it possible for a tie rod end to be bad enough to get a rejection sticker and not be able to tell it's bad? There is no vibration at any speed, no wandering on bumps, no slop in the steering wheel. The car feels great. BTW, my car already has turbo tie rods. They were put in by the PO. Not sure when.
Lou |
Spiderman
Suspicious, I'd go to a different inspector. Maybe he was having a bad day.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Are you sure it's the tie rod? Could be wheel bearing adjustment required?
Can you get someone to move the wheel with the car in the air whilst you check the various joints. You should be able to feel where the play is.
"Racing is Life. Anything that happens before, or after, is just waiting" 1988 Carrera 3.2 Sport Coupe - my mistress 2012 BMW F11 touring - the dog bus! 2017 VW T6 Transporter - the holiday bus/workhorse |
Just re-read and he's saying the [I]inner[I] end of the tie rod. Suspicious - I'm guessing he didn't really check at all, just felt some movement.
There is definitely a slight side to side movement with the suspension hanging. He just peeked up under there while moving the wheel and he said "definitely the inner tie rod end".
Not sure what to do now. I have a rejection sticker on the car and it's logged in the RMV database I have a front end issue. Can the inner end on the turbo tie rods wear out? I can see the outer but inner?
Lou |
Functionista
Move. Pack up your belongins and GTH outta there.
Inspection guy is clueless...
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Great suggestion Jeff!
Lou |
I see inners go bad just as often as the outers. Confirm the problem with the boot off and replace if needed
82 SC , 72 914 |
Thanks for your input porsche930dude. That's good to know. I will get under there and check it out.
Lou |
Just following up. As much as I hate to admit it, the technician at the inspection station was correct. The passenger inner tie rod end had some extra play in it. So, I replaced it today. The hardest part of the job was getting the spring retainers back on the boot. That was fun.
Thanks to all who commented.
Lou |
Did you pass inspection?
78 911SC sunroof Coupe (SOLD) 97 328i Convertible |
Not yet. I need to bring it back on Monday. They are closed today.
Lou |
Hopefully the same inspector is there ad you can thank him for his observation.
And hopefully that is all you need. Good luck.
Fleabit peanut monkey
Good point. I would search him out. You never know when dividends may pay out for kindness - over and above the fact that he deserves a pat on the back.
1981 911SC Targa |
I will definitely ask for him. If he's not there I will put a good word in with his boss.
Lou |
