bluetooth rpm sensor for e-motive tach output?
hello peeps, just asking the braintrust. i am trying to get a tach signal pulled off of the tach wire coming out of a tech3r electromotive ecu. the best would be if it were a bluetooth device , as i would like this device to talk to a dash mounted ipad mini running harrys laptimer! online you can find these devices which use the OBDII plug output to a bluetoooth device .. but i am surprised there are no other, non obd devices which would do this. any thoughts?
i might be asking way too much.. but what the hey.. thanks for looking..cheers frank |
| All times are GMT -8. The time now is 10:19 AM. |
