Soft Window Targa Help - need a tracing
After many years, finally got original, necessary, hard-to-get hardware to do a conversion. Still need the little tabs that get welded to the parcel shelf which hold the lower frame. If anyone has a car handy without the window on and can get to it, can I get a tracing of the tabs and dimensions? Approximate thickness? Closeup pics?
I'd like to make them as close to original as I possible can. Also there was lot of chatter about making the stainless steel trim that goes under the Targa bar. I'm still looking for that so if anyone has a pair?! Or did anyone end up making them? I assume they are more aesthetic than functional. Thanks! |
Try freezing14 might help you.
I will pm you and ill take the pict you need got 68 sooftie in garage.
Newly available trim.
FS: New REPRO SWT trim |
| All times are GMT -8. The time now is 10:13 PM. |
