-   -   Strange issue (http://forums.pelicanparts.com/porsche-911-technical-forum/804198-strange-issue.html)
aus911 04-03-2014 06:16 PM
Hi,
No problems, it is great that I could help.
As for the image, I found it on this forum originally posted by Hunt3r.
I have a 'dodgy' pdf copy of the Bentley manual(I think), mostly complete that I use as my reference.
Cheers
Ray
E Sully 04-04-2014 09:19 AM
Originally Posted by FLYONWALL9 (Post 7996759)
This is great!
Thanks everyone for your reply.
I just got off the phone with our fine host and ordered both the DME relay
and fuel pump relay
. If it doesn't turn out to be either, it cant hurt to have
them on hand. I'll give a shot to the jumper, I have a boat load of resistors
that I was given. Just have to find the magnifying glass so I can read the
values.
One great thing about PIA troubleshooting is the amount of info you learn
the hard way.
GREAT STUFF GUYS, again, thank you all and have a blessed weekend.
Scott
Scott,
The DME relay is the fuel pump relay on the 3.2 Carreras. If you also ordered the Red fuel pump relay, it was only used on pre '84 cars.
The jumper for the test is just a simple wire, no resistor is needed.
FLYONWALL9 04-10-2014 08:18 PM
Ahhhh yes, I did also order the red relay. Then again, the English gent that sold
it to me said it was for the fuel pump. Oh well, I suppose I have an extra relay
now.
I did try the DME relay today and still had the issue. So, I suppose the next step
is to do the jumper test to see if that will cure this problem. joy joy joy... :)
Thank you Ed for your reply
S
wwest 04-11-2014 09:28 AM
Check the flywheel geartooth speed and rotation position sensors.
VMAX1 04-11-2014 11:01 AM
I would check all the grounds, and make sure they are tight. To the left and behind the fuel filter, on the left side of the intake manifold and a ground strap that bolts to the body, under the car and on the passenger side.
FLYONWALL9 04-19-2014 09:02 PM
WELL,
It seems my last resort could be the most expensive in the quest to fix this issue.
Just to bring everyone up to date and perhaps save time for any new readers.
I have tried a new DME
Bypass the white plug/jumper
Fuel pump is good/runs strong I can hear it run when this problem happens
Checked all grounds and power at all connections
So, the speed and rotation position sensor is my last choice and I suppose
should have been the 1st thing to change. Because the RPM gauge jumps
all over when the car is revved. But, I have had this same issue due to bad
ground and low power.
With the above, who seems to have the best price on this part?
Lastly, does this seem to be a strange issue because the car did not have this
problem before the engine was removed? Just seems to have manifested after
it was reinstalled....
Thanks everyone, hope you all have a blessed Easter.
Scott
FLYONWALL9 04-19-2014 09:07 PM
Looks like I'll be doing this test 1st before ordering....
How To Test RPM & TDC Sensors in 944 and 911 3.2 Carrera Porsches - YouTube
Smoove1010 04-20-2014 05:27 AM
Scott,
Our host sells these sensors for BMW, made by Bosch, that are a good deal less expensive than the Porsche-specific ones. Here's one of many threads on the subject. I purchased two of these when I did my top end, they work perfectly.
http://forums.pelicanparts.com/porsche-911-technical-forum/499311-carrera-bmw-timing-mark-sender-interchangeable-part-number.html
I hope this does it for you!
GK
FLYONWALL9 04-20-2014 01:19 PM
Originally Posted by Smoove1010 (Post 8024328)
Scott,
GK
GK,
I had a feeling they would be on offer for some other brand vehicle,
just wasn't sure which one it would be.
Just to make sure I didn't fall all the way off my rocker when I was
installing the engine. The end plugs for both of these sensors, they
aren't the same are they? Making sure I didn't plug them into the
wrong socket (so to speak) if they would even work in reverse?
Looking at the video above they have close to the same value, this
is what brought me the question last night when I couldn't sleep.
gamin 04-20-2014 03:09 PM
Reference sensors are identical. You can reverse them easily. The car will not start at all if they are reversed. Since the car starts they are not reversed. I am betting on the fuel pump.
FLYONWALL9 04-20-2014 03:17 PM
Gary,
Would you still bet on the fuel pump if the RPM gauge were jumping around
erratic?
When I got the DME relay a few days ago, I installed and was able to drive
that day with zero issues aside from the RPM gauge not reading proper. Then
a few days passed, went to use the car to get carryout and the old issue pops
up.
