911 Sc keys
I just recently bought my first Porsche 1978 Sc It only has 1 key..Can you just buy blanks on ebay and have then re keyed by a locksmith..Thanks
Under the radar
Yes, check here. Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
Ok Thanks Track
I recently went to a door lock store I guess they are locksmiths they had the key I think it's a p7 key
They cut one for me it works fine Before that I went to a couple big chain stores like Home Depot etc and they don't carry out keys here in canada |
A good locksmith shop should have the proper blank on hand. I think it was around 7-10$ last time I had one made.
Fb = M/S
I have an 81 SC. If the keys are the same as mine, I think originally you would have had a lighted key, a red valet key and a black key that opens everything. The only difference between the red and black keys are the grooving. The key cuts are identical. I bought my key blanks here from Pelican.
I suggest you find a good locksmith that has experience cutting Porsche keys. It was unbelievably hard to find a good one when I had my keys made. First one I went to screwed up an expensive lighted key blank. |
RETIRED
Getting harder to find....steel key, many won't cut one and if you want a lighted head....ooiph.
Contact Tony E at daskeyman@verizon.net He be the schizzle.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
Get this $38 upgrade and don't look back....
Locksmith
What Fuchs said! My local locksmith scoffed at the idea that I had to pay $20 bucks for a blank.....he made me two keys for less than $10 I think. I still plan to buy a fancy one with a light in it and convert it to LED......I'm saving up Scott P.S. They're just plain and flat but they work and the car only came with one key?
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
I bought the black blank off our host as well as the lighted blank. I brought them to my local hardware store. The guy said he cut thousands of keys but never a Porsche key. He was apprehensive and told me he wasn't responsible if they didn't work. They work like a champ, and it cost me $8 (excluding blank cost). Only suggestion I have is the have the lighted blank cut before assembling it into the head.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
Straight shooter
Had a new crest lighted blank cut last year when I was in a similar situation. The local hardware store guru who has been cutting for 30yrs got it done. The machine barely has anything to bite when you get to the second side. More than once he had to stop and fish the blade out of the machine to reset and start again.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
I read somewhere before that if you have a genuine Porsche blank, that dealerships will cut them for free. I plan to test that very soon.
