Anybody know rocker trim washer order of install?
I'm putting the rocker trim back on an '87 Carrera and I can't remember -- if I ever actually knew -- the order that all of those plastic washers go.
Anybody know off hand? Thanks! - Matt
http://www.unobtanium-inc.com 356 Registry 17369 Early 911S Registry 912 Registry, PCA |
Should only be 1 plastic washer I think (at least on an 81). Car, plastic washer, rocker tab, metal washer, self taping "bolt".
Todd
'81 SC |
Thanks Todd. I think I got it figured out. I had to remember that they used different amounts of space per side depending on oil lines. Much appreciated! - Matt
Check the PET probably you can find it there.
1984 Porsche Carrera
toddu has it correct 5mm ones go on the oil line side 10mm spacers go on opposite side
On disassembly this car yielded a 5mm spacer on the oil line side which seems usual, but the other side had a 5mm AND a 10mm on each bolt. PET shows only one spacer per side, too, so I was confused. - Matt
