a marker light scoup helps too. the fan wont do much good without air
Dont ever go back to Pigeon Forge. That will cure the main problem but I dont seem to have overheating issue; just the AC will quit cooling in those conditions.
Love the wheel tyre look, what r u running?
They are 16x7 up front and 16x8 in the rear. I can't remember if they are 205 and 245 or 225 and 245. |
I chased the same problem in Virginia for a while. Stop and go in 95F and I was getting way up there. Engine mounted oil cooler thermostat was bad. After changing it I can run in 95F stop and go for over an hour with the Griffiths a/c on and not get above 9 o clock on the oil temp.
| All times are GMT -8. The time now is 03:16 AM. |
